1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: base 3-14-11 and breakpoint tables for ai and ao
To: "[email protected] ([email protected])" <[email protected]>
Date: Fri, 5 Nov 2010 12:36:28 +1100
Hi All,
I have noticed that breakpoint tables in base 3-14-11 require the table name to be all numeric characters.  This appears consistent with line 634 in dbStaticRun.c, where the first non numeric character must be '\0'.  However, according to page 105 of the 3-14-11 application developers guide, the breakpoint table name can consist of any alpha-numeric characters.  So, there seems a problem here. ?  For now, I am renaming my breakpoint tables.
Anyone else find similar issues ?
Cheers,
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Mail: [email protected]
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: base 3-14-11 and breakpoint tables for ai and ao J. Lewis Muir
Re: base 3-14-11 and breakpoint tables for ai and ao Ralph Lange
Re: base 3-14-11 and breakpoint tables for ai and ao Andrew Johnson
Prev: Re: making edm draw the desired related display based on value of a PV Dayle Kotturi
Next: Re: base 3-14-11 and breakpoint tables for ai and ao J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Solais 10 3.14.10 build problem Allison, Stephanie
ANJ, 05 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
