Hi Eric,
I suspect the problem is that the broadcast messages from the client are not making it through the firewall. I had a similar problem with a Windows firewall.
You can run ethereal on another machine and see if it is seeing the client broadcasts.
Sent: Thu 11/4/2010 10:22 AM
To: EPICS Techtalk
Subject: Firewall (iptables) issues?
Apologies if this is a FAQ. I'm new to the intricacies of Linux firewalls.
I'm trying to get a linux system
Linux xildev2 2.6.18-194.11.3.el5.lbl1 #1 SMP Thu Sep 16 14:50:58 PDT 2010 x86_64 x86_64 x86_64 GNU/Linux
to work as a channel access client.
If I use EPICS_CA_ADDR_LIST to explicitly provide the address of my IOC things work fine. If I leave EPICS_CA_ADDR_LIST undefined my client applications see no PVs.
I poked holes in the firewall for the channel-access ports:
iptables -L
ACCEPT udp -- anywhere anywhere udp dpt:ca-1
ACCEPT udp -- anywhere anywhere udp dpt:ca-2
ACCEPT tcp -- anywhere anywhere tcp dpt:ca-1
ACCEPT tcp -- anywhere anywhere tcp dpt:ca-2
but that didn't seem to make any difference.
I restarted caRepeater after making the firewall changes. Still no PVs.
Suggestions?
Eric Norum
[email protected]
- Re: Firewall (iptables) issues? Eric Norum
- Re: Firewall (iptables) issues? Matthieu Bec
- Firewall (iptables) issues? Eric Norum
<2010>
<2010>
