Tim and Jay,
I'm confused. Jay's original message said:
"... start the scan and the vxWorks terminal reports the following (with debug_saveData =10, debug_saveDataMsg=10)"
"... I'm using epics-3-14-11 with VxWorks and compiling with cygwin on windows-x86."
Which implies that Jay has saveData running on vxWorks. But I think Tim is talking about a possible problem arising from the Cygwin switch to the new xdr code (tirpc), which should not affect cross-compiling Cygwin to vxWorks, only code running locally on Cygwin?
From: [email protected] on behalf of Tim Mooney Sent: Wed 11/3/2010 1:51 AM To: Jay Steele; EPICS tech-talk Subject: Re: FW: write failure occuring in writeScanRecInProgress function(after writing header) in saveData.c (sscan-2-6-6 module)
Jay, This is trouble, though I don't know why xdr_setpos() is returning an error. I've found on the web indications that others have had trouble with xdr_setpos() not working on some streams (ref http://linux.die.net/man/3/xdr_setpos) but I haven't found out why. It may simply be that folks neglected to implement the function in the xdr library, when they switched cygwin over to new code. If worse comes to worst, I could recode saveData so it does the xdr writes "by hand", instead of relying on an xdr library. But I'd like to find out more before doing that. Tim On 11/2/2010 6:21 PM, Jay Steele wrote:
Yes - xdr_setpos is returning 0. What does this mean?
Jay Steele
From: Jay Steele Sent: Tuesday, November 02, 2010 3:51 PM To: Tim Mooney Cc: [email protected] Subject: RE: write failure occuring in writeScanRecInProgress function (after writing header) in saveData.c (sscan-2-6-6 module)
Hi Tim,
The function is exiting out of this block of code (I added the printf("write failed\n") line).
if (pscan->old_npts < pscan->npts) { writeFailed |= !xdr_setpos(&xdrs, pscan->dims_offset); Debug3(2, "saveData:writeScanRecInProgress:(%s) scan_dim=%d, dims_offset=%ld\n", pscan->name, pscan->scan_dim, pscan->dims_offset); if (writeFailed) { printf("write failed\n"); goto cleanup; } lval = pscan->npts; writeFailed |= !xdr_long(&xdrs, &lval); }
Cheers,
Jay Steele
From: Tim Mooney [[email protected]] Sent: Tuesday, November 02, 2010 3:47 PM To: Jay Steele Cc: [email protected] Subject: Re: write failure occuring in writeScanRecInProgress function (after writing header) in saveData.c (sscan-2-6-6 module)
Jay, The next thing saveData wants to do, after the last message you've shown, is to call xdr_setpos(), and I'm pretty sure this will be its first call to xdr_setpos() for the file. I'll guess xdr_pos() is returning an error (zero). Can you check to see if this is true? Tim Mooney Jay Steele wrote:
Hi EPICS tech-talk,
I'm having a problem executing my first simple 1D scan here at XRadia. I set up the scan as simply as I could - with one positioner and one data source (SIS 3820 board with input to channel #9 from a signal generator). I am using TPMAC records (e.g., bkgfix1pcs_scanrec_v3.db and AssyGeneric_scanrec_v3.db to set up records) for the positioner. I verified that the SIS 3820 record works to count the pulses from the signal generator, and also that I can move the motor simply by setting 21:D3:BNP:XY:PX:RqsPos. I start the scan and the vxWorks terminal reports the following (with debug_saveData =10, debug_saveDataMsg=10) and keeps trying to write to the scan file without success. Attached is a screen shot of the MEDM interface for the scan. I'm using epics-3-14-11 with VxWorks and compiling with cygwin on windows-x86.
saveDataTask: MSG_SCAN_PXNV, ix=0, val=2.000000 21:D3:BNP:scan1 MSG_SCAN_PXNV(2)= 0.000000 saveDataTask: MSG_SCAN_PXNV, ix=0, val=0.000000 21:D3:BNP:scan1 MSG_SCAN_PXNV(0)= 0.000000 saveDataTask: MSG_DESC, val= MSG_DESC()= 0.000000
nb_scan_running=1 saveDataTask: MSG_SCAN_DATA, val=0 proc_scan_data(21:D3:BNP:scan1):entry:pmsg->val=0 scan started: 21:D3:BNP:scan1 Checking number of valid positioner Checking number of valid detector Checking number of valid trigger Outermost scan proc_scan_data(21:D3:BNP:scan1):New file saveData: stat returned -1 for filename '/data/Nov-1-2010/test_0008.mda'; errno= 3145730 saveData:writeScanRecInProgress: Opening file '/data/Nov-1-2010/test_0008.mda' saveData:writeScanRecInProgress: Writing file header saveData:writeScanRecInProgress: scan_dim=1 saveData:writeScanRecInProgress:(21:D3:BNP:scan1) scan_dim=1, dims_offset=0 saveData:writeScanRecInProgress: File Header written saveData:writeScanRecInProgress: Writing per-scan header saveData:writeScanRecInProgress: Save scan info saveData:writeScanRecInProgress: Pos[0] info saveData:writeScanRecInProgress: Det[0] info saveData:writeScanRecInProgress: Trg[0] info saveData:writeScanRecInProgress: Allocate space for Pos[0] saveData:writeScanRecInProgress: Allocate space for Det[0] saveData:writeScanRecInProgress:(21:D3:BNP:scan1) scan_dim=1, dims_offset=0
From this output, I tracked the problem down to a write failure in the writeScanRecInProgress function in saveData.c. This occurs after the function writes out the file header and allocates space for Pos[0] and Det[0].
I'm confused why there would be a write failure at this point. Can anybody determine from this problem what might be wrong with my setup to cause this problem?
Jay Steele
XRadia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Software Services Group, Advanced Photon Source, Argonne National Lab. |
