Hi Tim,
The function is exiting out of this block of code (I added the printf("write failed\n") line).
if (pscan->old_npts < pscan->npts) {
writeFailed |= !xdr_setpos(&xdrs, pscan->dims_offset);
Debug3(2, "saveData:writeScanRecInProgress:(%s) scan_dim=%d, dims_offset=%ld\n",
pscan->name, pscan->scan_dim, pscan->dims_offset);
if (writeFailed) {
printf("write failed\n");
goto cleanup;
lval = pscan->npts;
writeFailed |= !xdr_long(&xdrs, &lval);
Cheers,
Jay Steele
Sent: Tuesday, November 02, 2010 3:47 PM
To: Jay Steele
Cc: [email protected]
Subject: Re: write failure occuring in writeScanRecInProgress function (after writing header) in saveData.c (sscan-2-6-6 module)
Jay,
The next thing saveData wants to do, after the last message you've shown,
is to call xdr_setpos(), and I'm pretty sure this will be its first call to xdr_setpos()
for the file. I'll guess xdr_pos() is returning an error (zero). Can you check to see
if this is true?
Tim Mooney
Jay Steele wrote:
Hi EPICS tech-talk,
I'm having a problem executing my first simple 1D scan here at XRadia. I set up the scan as simply as I could - with one positioner and one data source (SIS 3820 board with input to channel #9
from a signal generator). I am using TPMAC records (e.g., bkgfix1pcs_scanrec_v3.db and AssyGeneric_scanrec_v3.db to set up records) for the positioner. I verified that the SIS 3820 record works to count the pulses from the signal generator, and also that I
can move the motor simply by setting 21:D3:BNP:XY:PX:RqsPos. I start the scan and the vxWorks terminal reports the following (with debug_saveData =10, debug_saveDataMsg=10) and keeps trying to write to the scan file without success. Attached is a screen shot
of the MEDM interface for the scan. I'm using epics-3-14-11 with VxWorks and compiling with cygwin on windows-x86.
saveDataTask: MSG_SCAN_PXNV, ix=0, val=2.000000
21:D3:BNP:scan1 MSG_SCAN_PXNV(2)= 0.000000
saveDataTask: MSG_SCAN_PXNV, ix=0, val=0.000000
21:D3:BNP:scan1 MSG_SCAN_PXNV(0)= 0.000000
saveDataTask: MSG_DESC, val=
MSG_DESC()= 0.000000
nb_scan_running=1
saveDataTask: MSG_SCAN_DATA, val=0
proc_scan_data(21:D3:BNP:scan1):entry:pmsg->val=0
scan started: 21:D3:BNP:scan1
Checking number of valid positioner
Checking number of valid detector
Checking number of valid trigger
Outermost scan
proc_scan_data(21:D3:BNP:scan1):New file
saveData: stat returned -1 for filename '/data/Nov-1-2010/test_0008.mda'; errno=
3145730
saveData:writeScanRecInProgress: Opening file '/data/Nov-1-2010/test_0008.mda'
saveData:writeScanRecInProgress: Writing file header
saveData:writeScanRecInProgress: scan_dim=1
saveData:writeScanRecInProgress:(21:D3:BNP:scan1) scan_dim=1, dims_offset=0
saveData:writeScanRecInProgress: File Header written
saveData:writeScanRecInProgress: Writing per-scan header
saveData:writeScanRecInProgress: Save scan info
saveData:writeScanRecInProgress: Pos[0] info
saveData:writeScanRecInProgress: Det[0] info
saveData:writeScanRecInProgress: Trg[0] info
saveData:writeScanRecInProgress: Allocate space for Pos[0]
saveData:writeScanRecInProgress: Allocate space for Det[0]
From this output, I tracked the problem down to a write failure in the writeScanRecInProgress function in saveData.c. This occurs after the function writes out the file header and allocates space for Pos[0] and Det[0].
I'm confused why there would be a write failure at this point. Can anybody determine from this problem what might be wrong with my setup to cause this problem?
Jay Steele
XRadia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error,
please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
