1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: monitors received out of order
To: [email protected]
Date: Tue, 2 Nov 2010 23:39:40 +0100
On Dienstag, 2. November 2010, [email protected] wrote:
> I am not sure what to do about it now, but I definitely have a
> frequent requirement to get a coherent set of data from a server. Up
> till now, I have monitored everything and then taken a snapshot
> whenever I got a monitor from the last item in a processing chain
> (which I have ensured always updates whenever the chain processes).
> This has seemed to work with VxWorks servers. I would like to still
> be able to achieve the same effect. How else can I do this?
I think there is one reliable way that should work, although I have not
tested it. Please correct me if I am making wrong assumptions.
The idea is that all the records in your set use TSEL to point to
the 'start' record of your processing 'queue'. If the records in your
set are linked via FLNK, they now should all exactly agree on their
timestamp for one processing run. Then, in your client, you can group
events according to timestamp, i.e. you first wait for an event with a
new timestamp, remember it, and then wait until all the other slots in
your set have been filled by subsequent events with the same timestamp.
If your event groups are not clearly separated in time, i.e. different
event groups may overlap, you can add a small queue (2 or 3 elements)
of PV sets to be filled. Then the event handler can put values into the
right bucket (queue element) according to timestamp.
Cheers
Ben
Re: monitors received out of order Till Straumann
monitors received out of order Tim Mooney
RE: monitors received out of order Jeff Hill
RE: monitors received out of order nick.rees
Prev: write failure occuring in writeScanRecInProgress function (after writing header) in saveData.c (sscan-2-6-6 module) Jay Steele
Next: RE: write failure occuring in writeScanRecInProgress function (afterwriting header) in saveData.c (sscan-2-6-6 module) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: monitors received out of order Kate Feng
Next: Re: monitors received out of order Till Straumann
ANJ, 06 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
