[email protected] wrote on 02/11/10 10:26:
> [...] I definitely have a frequent requirement to get a coherent set of data from a server. Up till now, I have monitored everything and then taken a snapshot whenever I got a monitor from the last item in a processing chain [...] How else can I do this?
One "simple" solution is to combine your data into a single waveform using e.g.
the asub record.
But even then, I'm not sure if your waveform is save from containing "half
new/half old" data:
there is no "standard" mutex semaphore to prevent your data from being
overwritten while it is read.
If your data is distributed over many IOCs, things get more complicated (but you
did know that ;-)
Pulsed machines, like LCLS or the SwissFEL, have very tough requirements on
synchronous data taking over the network.
Those solutions are generic and could be used on a single IOC, too. See e.g.:
http://www.slac.stanford.edu/grp/lcls/controls/global/sw/slc_ioc/bsac/BSACDesign.htm
or
http://cern.ch/AccelConf/icalepcs2009/papers/wep026.pdf
But this is really not simple anymore.
If anyone comes up with a simpler but still reliable solution, I would be glad
to hear it :-)
Andreas
For every complex problem, there is a solution that is simple, neat, and wrong.
-- H. L. Mencken
- monitors received out of order Tim Mooney
- RE: monitors received out of order Jeff Hill
- RE: monitors received out of order nick.rees
Re: monitors received out of order Ernest L. Williams Jr.
<2010>
<2010>
