Title: Re: cygin-x86-debug behavior
I just built the EPICS example application for cygwin-x86-debug on my
local PC and it works with COMMANDLINE_LIBRARY=EPICS.
The failure I am seeing is coming from a build of a more complex
application on a server file system. I will try to figure out if it is a
configuration difference (e.g. if the example application fails there) or if it
is due to some other library that is being used by the more complex
application.
Sent: Saturday, October 30, 2010
9:02 PM
To: Eric
Norum
Cc: Andrew Johnson;
[email protected]
Subject: RE: cygin-x86-debug
behavior
Can you try cygwin-x86-debug with
COMMANDLINE_LIBRARY=EPICS and the simple example application and see if it
fails for you?
3.14.11 with COMMANDLINE_LIBRARY=EPICS works fine on
darwin-x86
On Oct 30, 2010, at 7:18 AM, Mark Rivers wrote:
> I changed CONFIG_SITE.cygwin-x86.cygwin-x86-debug to have the line
> COMMANDLINE_LIBRARY=READLINE
> That caused the application to be built using the readline library, which
is apparently not the default for this arch in the distributed version of base
3.14.11. The application then works fine, it does not hang waiting for
console input.
> There appears to be a serious bug in the implementation of console input
when NOT using readline. I would be surprised if this bug only affects
cygwin-x86-debug, since that arch is very similar to normal cygwin-x86.
Has anyone tested not using readline on cygwin-x86, linux-x86 or other archs?
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Fri 10/29/2010 6:44 PM
> To: Mark Rivers; Andrew Johnson
> Cc: [email protected]; [email protected]
> Subject: RE: cygin-x86-debug behavior
> I just built base with COMMANDLINE_LIBRARY=EPICS for
cygwin-x86-debug. I get the same behavior as without setting this:
> - readline does not seem to be running, i.e. I cannot recall my last line,
etc.
> - The IOC hangs waiting for input from the console. I can press a
button in medm and nothing happens until I hit CR on the console a bunch of
times.
> Note that even without setting the COMMANDLINE_LIBRARY flag readline is
not being used on this architecture. I will next try setting
COMMANDLINE_LIBRARY=READLINE to explicitly turn it on and see if that fixes the
problem.
> Mark
> From: Mark Rivers
> Sent: Fri 10/29/2010 6:35 PM
> To: Andrew Johnson
> I just looked carefully at the build output before I made any changes to
base. I am building cyginx-86-debug as a cross-compile of cygwin-x86,
since this is what is supported in base 4.11.
> Here is the output when it builds for cygwin-x86. Note that it is linking
with readline and curses.
> g++ -o dxpApp.exe -static
-Lj:/epics/devel/dxp-3-0_handel_1_1_4/lib/cygwin-x86
-L/corvette/home/epics/devel/areaDetector-1-6/lib/cygwin-x86
> -L/corvette/home/epics/devel/asyn-4-14/lib/cygwin-x86
-L/corvette/home/epics/devel/autosave-4-7/lib/cygwin-x86
> busy-1-2/lib/cygwin-x86
-L/corvette/home/epics/devel/calc-2-8/lib/cygwin-x86
-L/corvette/home/epics/devel/mca-6-12-1/lib/cygwin-x86 -L/corve
> tte/home/epics/devel/seq-2-0-12/lib/cygwin-x86 -L/corvette/home/epics/devel/sscan-2-6-6/lib/cygwin-x86
-L/corvette/usr/local/epics/base-3.14
> .11/lib/cygwin-x86
-m32
dxpMain.o dxp_registerRecordDeviceDriver.o -ldxp -lhandel
-lmca -lasyn -lcalc -lsscan -lautos
> ave -lbusy -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc
-ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lNDPlug
> in -lADBase -lnetCDF -lcalc -lbusy -lsscan -lautosave -lmca -lasyn
-lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -l
> registryIoc -ldbStaticIoc -lca -lCom -llibNeXus.dll -llibGraphicsMagick++
-llibGraphicsMagickWand -llibGraphicsMagick -lliblcms -llibpng14 -
> llibbz2 -llibfreetype -llibtiff -llibjpeg -llibjbig -llibz
-llibxml2.dll -lDLPORTIO -lPlxApi -lsetupapi -ltirpc -ltirpc -lGdi32
-lpthread
> -lreadline -lcurses -lm
> Here is the output when it builds for cygwin-x86-debug. Note that it
is NOT linking with readline and curses, but I have done nothing in my base
configuration to turn off readline.
-Lj:/epics/devel/dxp-3-0_handel_1_1_4/lib/cygwin-x86-debug
> n-x86-debug -L/corvette/home/epics/devel/asyn-4-14/lib/cygwin-x86-debug
-L/corvette/home/epics/devel/autosave-4-7/lib/cygwin-x86-debug -L/co
> rvette/home/epics/devel/busy-1-2/lib/cygwin-x86-debug
-L/corvette/home/epics/devel/calc-2-8/lib/cygwin-x86-debug
> l/mca-6-12-1/lib/cygwin-x86-debug
-L/corvette/home/epics/devel/seq-2-0-12/lib/cygwin-x86-debug -L/corvette/home/epics/devel/sscan-2-6-6/lib/
> cygwin-x86-debug
-L/corvette/usr/local/epics/base-3.14.11/lib/cygwin-x86-debug
-m32
> iver.o -ldxp -lhandel -lmca -lasyn -lcalc -lsscan
-lautosave -lbusy -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc
-ldbtoolsIoc -la
> sIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lNDPlugin -lADBase
-lnetCDF -lcalc -lbusy -lsscan -lautosave -lmca -lasyn -lrecIoc -lso
> ftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc
-ldbStaticIoc -lca -lCom -llibNeXus.dll -llibGraphicsMagick++ -llibG
> raphicsMagickWand -llibGraphicsMagick -lliblcms -llibpng14 -llibbz2
-llibfreetype -llibtiff -llibjpeg -llibjbig -llibz -llibxml2.dll -lDLPO
-lpthread -lm
> So maybe the problem is the opposite of what I thought, and readline is
not being use and that is causing the problem?
> Mark
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Fri 10/29/2010 5:40 PM
> To: Mark Rivers
> Subject: Re: cygin-x86-debug behavior
> On Friday 29 October 2010 17:21:05 Mark Rivers wrote:
>> I was about to add the flag
>> COMMANDLINE_LIBRARY = EPICS
>> to CONFIG_SITE.cygwin-x86.cygwin-x86-debug.
>> If I do that how much of base do I need to rebuild?
> I think just libCom. It will then want to re-link all of its
executables in
> the other directories, but I don't think it's essential that it do that.
> Good luck, I have to leave now.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
Eric Norum
[email protected]
- RE: cygin-x86-debug behavior Mark Rivers
RE: epics3.14.8.2 problems on win32-x86 Mark Rivers
RE: Attention, poll: Who needs the sequencer's pv layer? Chestnut, Ronald P.
<2010>
Re: cygin-x86-debug behavior J. Lewis Muir
<2010>
ANJ, 01 Nov 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
