I suspect that your problem could be with the version of "make" you are using. There are multiple versions called "3.81", but the newer one that comes with Cygwin does not work. You can get a working version here:
http://cars9.uchicago.edu/software/pub/make.gz
Unzip that file into the cygwin /bin directory.
I don't think edits 1 and 3 that you did should be done, those are probably because of the problem with make. I don't know about edit 2.
Sent: Mon 11/1/2010 6:23 AM
To: [email protected]
Subject: epics3.14.8.2 problems on win32-x86
Hi All,
I can install EPICS BASE 3.14.8.2 on win32-x86, but when I executed "makeBaseApp.pl -t example example" and "makeBaseApp.pl -i -t example example" to create a epics application, no files or directories had been generated and no error information appears.
I use Visual C++6.0,Perl 5.8.7 and gnu make 3.81. before installing base, I have changed the following three files:
1. In <base>/configure/RULES_BUILD,I edit "$<*" to "$<" in order to avoid the error "Can't find file 'Com.dll*'" when compiling base.
2. In <base>/src/gdd/dbMapper.cc, I edit the second "int i" to "int j" in the following code, in order to avoid the error "error C2374:'i':redefinition;multiple initialization" when compiling base.
for ( int i=0; i < db->no_str; i++ ) {
enumStringTable.getString ( i,
&(db->strs[i][0]), MAX_ENUM_STRING_SIZE );
for ( int i = db->no_str; i < MAX_ENUM_STATES; i++ ) {
db->strs[i][0] = '\0';
3. In <base>/src/makeBaseApp/makeBaseApp.pl ,I edit "$epics_base =~ s|(/.*)/bin/.*makeBaseApp.*|$1|;" to "$epics_base =~ s|^(.*)/bin/.*makeBaseApp.*|$1|;" in line 173, and add "elsif ($^O eq 'MSWin32') { $newpath =~ s|\\|/|go; }" in line 484. Otherwise, "Can't find EPICS base" when executing makeBaseApp.pl.
Now that no error occurs, why no files generated when makeBaseApp? It's very strange, does anyone have met this problem?
Lin Wang
- Re: epics3.14.8.2 problems on win32-x86 Ralph Lange
- Re: epics3.14.8.2 problems on win32-x86 çæ
- RE: epics3.14.8.2 problems on win32-x86 Jeff Hill
- epics3.14.8.2 problems on win32-x86 王林
<2010>
<2010>
