Hi Tech-talk,
I'm using epics-3-14-11, mca-s55 to try to control a Struck (SIS) 3820 VME board. I'm using a PPC mother board running vxWorks.
I run the following in my startup script using the examples in mca-s55/iocBoot/iocVxWorks for SIS3820.
mcaSIS3820Setup(0xA0000000, 224, 6)
mcaSIS3820Config("mcaSIS3820/1", 0, 2048, 32, 2, 0, 1000000)
dbLoadTemplate("SIS3820_32.substitutions")
I get the following error after pmacVmeInit:
drvMcaSIS3820Asyn::drvUserCreate, unknown command=ACQUIRING
21:D3:BNP:scalar1:ReadCallback devAsynInt32::initCommon drvUserCreate
This error seems to come from the following in SIS3820_32.substitutions.
file "$(MCA)/SIS3820.db"
pattern
{P, INP}
{21:D3:BNP:scalar1:, "@asyn(mcaSIS3820/1 0)"}
and SIS3820.db:
record(ai,"$(P)ReadCallback") {
field(SCAN,"I/O Intr")
field(DTYP, "asynInt32")
field(INP, "$(INP)ACQUIRING")
field(FLNK, "$(P)ReadAll.PROC PP MS")
When I change "ACQUIRING" to "MCA_ACQUIRING" (based on a quick review of the source code), the script seems to work correctly. Is this the correct solution?
Also assuming that the correct command is "MCA_ACQUIRING" - when I run scaler32_full.adl to see the data from the SIS3820 board and have a signal generator generating a 3.3V pulse train at 25 Hz connected to input #9, I only
see the counts from the internal clock at input #1. Anybody have any hints on how to activate input #9? Attached is the screen shot from the MEDM screen.
Jay Steele
XRadia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error,
please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
