1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Some Channel Access Questions
To: [email protected]
Date: Thu, 28 Oct 2010 00:29:26 +0200
On Mittwoch, 27. Oktober 2010, Tim Mooney wrote:
> One point that is probably obvious to you guys, but was obvious to me
> only in retrospect,
> is that it matters *where* in the processing chain the asynchronous
> record occurs.
It was not obvious to me, thanks for pointing it out.
> If the only asynchronous record in the chain is the first one, you
> can get good behavior
> from a sequence of ca_put_callbacks and be fooled into thinking that
> server-side code
> is more aware of putNotify than it actually is.  This is because the
> first record's PACT field
> will be True all the while the putNotify is active, so server-side
> code, which only honors
> record locks and PACT fields, will accidentally be honoring putNotify
> as well.
> To make a good ca_put_callback test, you have to write to a
> synchronous record that links
> to an asynchronous record.  In this case, when the first record has
> written to the asynchronous
> record, and that record has gone into its asynchronous wait, both the
> lockset and the
> first record's PACT field will look ready for another
> ca_put_callback, but the putNotify
> fields will not be ready, and you'll be able to see the problem you
> need to defend against.
Jeff, can you confirm this, i.e. does the server only look at PACT, and
not at the putNotify fields? If yes, do we treat this as a CA bug (to
be fixed in the next base release)?
(I may offer a work-around in any case, but I'd still like to know what
the specified behaviour is, so that work-arounds can be marked as such
and phased out when implementation and spec cease to differ.)
Cheers
Ben
Some Channel Access Questions Ben Franksen
RE: Some Channel Access Questions Jeff Hill
Re: Some Channel Access Questions Tim Mooney
Prev: Re: OMS MAXv announces fix Kurt Goetze
Next: EPICS Base 3.14.12-pre2 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Some Channel Access Questions Tim Mooney
Next: Re: Some Channel Access Questions Ben Franksen
ANJ, 08 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
