1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ChannelArchiver build problem with 3.14.11 on Suse linux
To: Burkhard Kolb <[email protected]>
Cc: tech-talk Mailing List <[email protected]>
Date: Wed, 27 Oct 2010 09:29:11 -0700
Burkhard Kolb wrote:
/usr/bin/g++ -o UnitTest -L/home/cbmdcs/EPICS/base-3-14-11/lib/linux-x86 -L/home/cbmdcs/EPICS/extensions/lib/linux-x86 -Wl,-rpath,/home/cbmdcs/EPICS/base-3-14-11/lib/linux-x86 -Wl,-rpath,/home/cbmdcs/EPICS/extensions/lib/linux-x86 -L/usr/local/lib -lxerces-c -m32 ASCIIParserTest.o AVLTreeTest.o AutoFilePtrTest.o AutoPtrTest.o BinIOTest.o BitsetTest.o CATest.o ConversionsTest.o FUXTest.o FilenameTest.o GenericExceptionTest.o GuardTest.o IndexConfigTest.o ListTest.o LockfileTest.o MemoryBufferTest.o MsgLoggerTest.o OrderedMutexTest.o ThreadTest.o ThrottleTest.o ThrottledMsgLoggerTest.o TimerTest.o epicsTimeHelperTest.o stdStringTest.o va_argTest.o UnitTest.o -lTools -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lreadline -lncurses -lm -lrt -ldl -lgcc
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../libxerces-c.so when searching for -lxerces-c
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib64/libxerces-c.so when searching for -lxerces-c
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: cannot find -lxerces-c
collect2: ld returned 1 exit status
make[2]: *** [UnitTest] Error 1
If you have not installed, Xerces XML Library that will be required.
Please provide more information about where you have installed the ThirdParty Libraries required for the ChannelArchiver.
Cheers, Ernest
Dr. Burkhard Kolb
Tel +49 6159 712667
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Dr. h.c. Horst Stöcker, Dr. Hartmut Eickhoff
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhard
Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
Prev: RE: EPICS CA problems Mark Rivers
Next: Re: Some Channel Access Questions Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
Next: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
ANJ, 24 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
