Hi Jeff,
The good news I that I have now reproduced this problem on my lab computer at the APS, so I am no longer trying to debug on someone else's system at NSLS.
It hung up when I was running an IDL client on the same machine as the IOC. It is a cygwin-x86 IOC. When it hung up this is the output of "epicsMutexShowAll 1"
epics> epicsMutexShowAll 1
ellCount(&mutexList) 78692 ellCount(&freeList) 0
epicsMutexId 0x13a9e888 source ../caservertask.c line 732
ownerTid 0x13a9f010 count 1 owned 1
So there is only 1 mutex with a lock.
This is the output of "casr 100"
epics> casr 100
Channel Access Server V4.11
Connected circuits:
TCP 164.54.160.82:57075(corvette.cars.aps.anl.gov): User="epics", V4.11, 19 Channels, Priority=0
Task Id=0x13736780, Socket FD=12
Secs since last send 1937.69, Secs since last receive 2059.90
Unprocessed request bytes=0, Undelivered response bytes=0
State=up
4968 bytes allocated
dxpXMAP:PixelsPerBuffer(1rw) dxpXMAP:PixelsPerBuffer_RBV(1rw) dxpXMAP:AutoPixelsPerBuffer(1rw)
dxpXMAP:BufferSize_RBV(1rw) dxpXMAP:CollectMode(1rw) dxpXMAP:PixelAdvanceMode(1rw)
dxpXMAP:SyncCount(1rw) dxpXMAP:IgnoreGate(1rw) dxpXMAP:InputLogicPolarity(1rw)
dxpXMAP:dxp1:CurrentPixel(1rw) dxpXMAP:NextPixel(1rw) dxpXMAP:PixelsPerRun(1rw)
dxpXMAP:AutoApply(1rw) dxpXMAP:Apply(1rw) dxpXMAP:MBytesRead_RBV(1rw)
dxpXMAP:ReadRate_RBV(1rw) dxpXMAP:SyncMasterChannel(1rw) dxpXMAP:GateMasterChannel(1rw)
dxpXMAP:LBUSMasterChannel(1rw)
Send Lock
epicsMutexId 0x13748318 source ../caservertask.c line 732
ownerTid 0x0 count 0 owned 0
Put Notify Lock
epicsMutexId 0x137355b0 source ../caservertask.c line 733
Address Queue Lock
epicsMutexId 0x13735630 source ../caservertask.c line 734
Event Queue Lock
epicsMutexId 0x13736238 source ../caservertask.c line 735
Block Semaphore
TCP 164.54.160.82:57112(corvette.cars.aps.anl.gov): User="epics", V4.11, 25 Channels, Priority=0
Task Id=0x100ebf38, Socket FD=3
Secs since last send 581.47, Secs since last receive 868.66
State=up
6480 bytes allocated
dxpXMAP:EraseAll(1rw) dxpXMAP:EraseStart(1rw) dxpXMAP:StartAll(1rw)
dxpXMAP:StopAll(1rw) dxpXMAP:Acquiring(1rw) dxpXMAP:Acquiring(1rw)
dxpXMAP:EnableClientWait(1rw) dxpXMAP:ClientWait(1rw) dxpXMAP:StatusAllOnce(1rw)
dxpXMAP:StatusAll(1rw) dxpXMAP:ReadAll(1rw) dxpXMAP:ReadAllOnce(1rw)
dxpXMAP:ReadLLParams(1rw) dxpXMAP:ReadLLParams(1rw) dxpXMAP:PresetMode(1rw)
dxpXMAP:ElapsedReal(1rw) dxpXMAP:PresetReal(1rw) dxpXMAP:ElapsedLive(1rw)
dxpXMAP:PresetLive(1rw) dxpXMAP:PresetEvents(1rw) dxpXMAP:PresetTriggers(1rw)
dxpXMAP:IDeadTime(1rw) dxpXMAP:DeadTime(1rw) dxpXMAP:PollTime_RBV(1rw)
dxpXMAP:PollTime(1rw)
Send Lock
epicsMutexId 0x1010c8e8 source ../caservertask.c line 732
Put Notify Lock
epicsMutexId 0x1010c5a8 source ../caservertask.c line 733
Address Queue Lock
epicsMutexId 0x139d57d0 source ../caservertask.c line 734
Event Queue Lock
epicsMutexId 0x1010ce60 source ../caservertask.c line 735
Block Semaphore
TCP 164.54.160.87:2797(XIA-Detector): User="epics", V4.11, 2329 Channels, Priority=0
Task Id=0x13a9f098, Socket FD=13
Secs since last send 584.48, Secs since last receive 584.48
Unprocessed request bytes=8256, Undelivered response bytes=4294967272
State=up
478560 bytes allocated
dxpXMAP:PresetMode(0rw) dxpXMAP:PresetReal(0rw) dxpXMAP:mca1(1rw)
dxpXMAP:mca1(1r-) dxpXMAP:mca1(1rw) dxpXMAP:mca1(1rw)
dxpXMAP:mca1(0rw) dxpXMAP:mca1(0rw) dxpXMAP:mca1(0rw)
dxpXMAP:mca2(1rw) dxpXMAP:mca2(1r-) dxpXMAP:mca2(1rw)
dxpXMAP:mca2(1rw) dxpXMAP:mca2(0rw) dxpXMAP:mca2(0rw)
dxpXMAP:mca2(0rw) dxpXMAP:mca2(0rw) dxpXMAP:mca2(0rw)
dxpXMAP:mca2(0rw) dxpXMAP:mca3(1rw) dxpXMAP:mca3(1r-)
dxpXMAP:mca3(1rw) dxpXMAP:mca3(1rw) dxpXMAP:mca3(0rw)
dxpXMAP:mca3(0rw) dxpXMAP:mca3(0rw) dxpXMAP:mca3(0rw)
dxpXMAP:mca3(0rw) dxpXMAP:mca3(0rw) dxpXMAP:mca4(1rw)
dxpXMAP:mca4(1r-) dxpXMAP:mca4(1rw) dxpXMAP:mca4(1rw)
dxpXMAP:mca4(0rw) dxpXMAP:mca4(0rw) dxpXMAP:mca4(0rw)
dxpXMAP:mca5(1rw) dxpXMAP:mca5(1r-) dxpXMAP:mca5(1rw)
dxpXMAP:mca5(1rw) dxpXMAP:mca5(0rw) dxpXMAP:mca5(0rw)
dxpXMAP:mca5(0rw) dxpXMAP:mca5(0rw) dxpXMAP:mca5(0rw)
dxpXMAP:mca5(0rw) dxpXMAP:mca6(1rw) dxpXMAP:mca6(1r-)
dxpXMAP:mca6(1rw) dxpXMAP:mca6(1rw) dxpXMAP:mca6(0rw)
dxpXMAP:mca6(0rw) dxpXMAP:mca6(0rw) dxpXMAP:mca6(0rw)
dxpXMAP:mca6(0rw) dxpXMAP:mca6(0rw) dxpXMAP:mca7(1rw)
dxpXMAP:mca7(1r-) dxpXMAP:mca7(1rw) dxpXMAP:mca7(1rw)
dxpXMAP:mca7(0rw) dxpXMAP:mca7(0rw) dxpXMAP:mca7(0rw)
dxpXMAP:mca8(1rw) dxpXMAP:mca8(1r-) dxpXMAP:mca8(1rw)
dxpXMAP:mca8(1rw) dxpXMAP:mca8(0rw) dxpXMAP:mca8(0rw)
dxpXMAP:mca8(0rw) dxpXMAP:mca8(0rw) dxpXMAP:mca8(0rw)
dxpXMAP:mca8(0rw) dxpXMAP:mca9(1rw) dxpXMAP:mca9(1r-)
dxpXMAP:mca9(1rw) dxpXMAP:mca9(1rw) dxpXMAP:mca9(0rw)
dxpXMAP:mca9(0rw) dxpXMAP:mca9(0rw) dxpXMAP:mca9(0rw)
dxpXMAP:mca9(0rw) dxpXMAP:mca9(0rw) dxpXMAP:mca10(1rw)
dxpXMAP:mca10(1r-) dxpXMAP:mca10(1rw) dxpXMAP:mca10(1rw)
dxpXMAP:mca10(0rw) dxpXMAP:mca10(0rw) dxpXMAP:mca10(0rw)
dxpXMAP:mca11(1rw) dxpXMAP:mca11(1r-) dxpXMAP:mca11(1rw)
dxpXMAP:mca11(1rw) dxpXMAP:mca11(0rw) dxpXMAP:mca11(0rw)
dxpXMAP:mca11(0rw) dxpXMAP:mca11(0rw) dxpXMAP:mca11(0rw)
dxpXMAP:mca11(0rw) dxpXMAP:mca12(1rw) dxpXMAP:mca12(1r-)
dxpXMAP:mca12(1rw) dxpXMAP:mca12(1rw) dxpXMAP:mca12(0rw)
dxpXMAP:mca12(0rw) dxpXMAP:mca12(0rw) dxpXMAP:mca12(0rw)
dxpXMAP:mca12(0rw) dxpXMAP:mca12(0rw) dxpXMAP:mca13(1rw)
dxpXMAP:mca13(1r-) dxpXMAP:mca13(1rw) dxpXMAP:mca13(1rw)
dxpXMAP:mca13(0rw) dxpXMAP:mca13(0rw) dxpXMAP:mca13(0rw)
dxpXMAP:mca14(1rw) dxpXMAP:mca14(1r-) dxpXMAP:mca14(1rw)
dxpXMAP:mca14(1rw) dxpXMAP:mca14(0rw) dxpXMAP:mca14(0rw)
dxpXMAP:mca14(0rw) dxpXMAP:mca14(0rw) dxpXMAP:mca14(0rw)
dxpXMAP:mca14(0rw) dxpXMAP:mca15(1rw) dxpXMAP:mca15(1r-)
dxpXMAP:mca15(1rw) dxpXMAP:mca15(1rw) dxpXMAP:mca15(0rw)
dxpXMAP:mca15(0rw) dxpXMAP:mca15(0rw) dxpXMAP:mca15(0rw)
dxpXMAP:mca15(0rw) dxpXMAP:mca15(0rw) dxpXMAP:mca16(1rw)
dxpXMAP:mca16(1r-) dxpXMAP:mca16(1rw) dxpXMAP:mca16(1rw)
dxpXMAP:mca16(0rw) dxpXMAP:mca16(0rw) dxpXMAP:mca16(0rw)
dxpXMAP:ElapsedLive(1rw) dxpXMAP:ElapsedReal(1rw) dxpXMAP:Acquiring(1rw)
dxpXMAP:ClientWait(1rw) dxpXMAP:EraseAll(0rw) dxpXMAP:StartAll(0rw)
dxpXMAP:ReadAll(0rw)
Send Lock
Put Notify Lock
epicsMutexId 0x13a9e980 source ../caservertask.c line 733
Address Queue Lock
epicsMutexId 0x13a9ea78 source ../caservertask.c line 734
Event Queue Lock
epicsMutexId 0x13a9eb70 source ../caservertask.c line 735
Block Semaphore
UDP Server:
UDP 164.54.160.100:1518(): User="", V4.0, 0 Channels, Priority=0
Task Id=0x133721f0, Socket FD=9
Secs since last send 936.94, Secs since last receive 0.58
Unprocessed request bytes=16, Undelivered response bytes=0
State=up
180 bytes allocated
Send Lock
epicsMutexId 0x133725a8 source ../caservertask.c line 732
Put Notify Lock
epicsMutexId 0x133726a0 source ../caservertask.c line 733
Address Queue Lock
epicsMutexId 0x13372798 source ../caservertask.c line 734
Event Queue Lock
epicsMutexId 0x13372890 source ../caservertask.c line 735
Block Semaphore
There are currently 286036 bytes on the server's free list
4 client(s), 699 channel(s), 1424 event(s) (monitors) 0 putNotify(s)
10 small buffers (16384 bytes ea), and 0 jumbo buffers (1000024 bytes ea)
The server's resource id conversion table:
Bucket entries in use = 2373 bytes in use = 54372
Bucket entries/hash id - mean = 0.579346 std dev = 0.493664 max = 1
The server's array size limit is 1000024 bytes max
Channel Access Address List
164.54.160.255:5065
epics>
164.54.160.87 is the IP address of the machine running both the IOC and the IDL client. For that client connection it is saying:
State=up
Can you provide any hints on what could be going wrong? Other diagnostics to print out?
Sent: Mon 10/25/2010 4:22 PM
To: Mark Rivers; 'tech-talk'
Cc: Antonio Lanzirotti
Subject: RE: EPICS CA problems
> TCP 172.16.1.21:1752(X26A-Data): User="X26A User", V4.11, 1837 Channels,
> Priority=0
> Task Id=0x12ec19d0, Socket FD=16
> Secs since last send 131528.55, Secs since last receive 140881.60
> Unprocessed request bytes=8296, Undelivered response bytes=0
> State=up
> 377424 bytes allocated
There are no response bytes pending, but request bytes _are_ pending (for a
long time). I am going to go out on a limb and guess that the server's
per-client receive thread is trapped in db_put_field waiting for the db scan
lock, or waiting in the device support's signal write function - probably
due to a device driver issue. The server's per-client lock is held by the
receive thread in this situation, and that would shutdown also subscription
updates to this client. The situation can be diagnosed in the debugger.
Typically the server's per-client receive thread is parked in socket
receive, and the server's per-client send thread is parked in event flag
wait. Symptomatic would be wedged in db_put_field (device driver issue) or
wedged always waiting for the same lock in the same place (deadlock).
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Monday, October 25, 2010 10:55 AM
> To: Jeff Hill; tech-talk
> Hi Jeff,
> I have some more information on this. The problem does NOT appear to be a
> problem with caRepeater crashing. When the client loses connection to the
> IOC the Windows Task Manager shows that caRepeater is still running on the
> IOC PC. Normally we had been seeing the problem when the client and the
> IOC were running on the same computer.
> However, last night we managed to reproduce the problem with the client
> running on a separate PC.
> I have attached the output of casr(100) on the IOC when the client has
> lost communication. The IOC server is 172.16.1.20 (X26A-Control) and the
> client is running on 172.16.1.21 (X26A-Data).
> It appears that when this happens the client loses connection to all PVs
> on the server. But we know for sure that it lost connection to
> X26A:med:Acquiring.
> I think I see something suspicious in the output. Here is the start of
> one block of output from casr for the client machine that has lost
> connection:
> TCP 172.16.1.21:1726(X26A-Data): User="X26A User", V4.11, 1755 Channels,
> Priority=0
> Task Id=0x12a022b0, Socket FD=15
> Secs since last send 0.02, Secs since last receive 0.02
> State=up
> 360696 bytes allocated
> X26A:med:PresetMode(0rw) X26A:med:ElapsedReal(1rw)
> X26A:med:PresetReal(0rw)
> Here is the start of another block for the same client:
> Priority=0
> State=up
> Note that there are unprocessed request bytes there.
> There is then another block for the same client machine:
> TCP 172.16.1.21:2735(X26A-Data): User="X26A User", V4.11, 1837 Channels,
> Priority=0
> Task Id=0x12ec0a10, Socket FD=19
> Secs since last send 119.81, Secs since last receive 119.82
> State=up
> There is also a UDP entry for that client machine:
> UDP Server:
> UDP 172.16.1.21:2733(): User="", V4.11, 0 Channels, Priority=0
> Task Id=0x1293c4e0, Socket FD=11
> Secs since last send 131525.68, Secs since last receive 3.06
> State=up
> 180 bytes allocated
> Send Lock
> I am not sure how to interpret this.
> Thanks,
> Mark
> From: Jeff Hill [mailto:[email protected]]
> Sent: Tuesday, October 19, 2010 10:33 AM
> Hi Mark,
> This is the first I have heard of any issues the ca repeater crashing.
> Is this running under cygwin or mingw? Compiled by ms visual c or gnu?
> The stack trace has no symbols so it's hard to determine a cause. If you
> could fire up the relevant debugger and get a stack trace with symbols
> that
> would help. You might need to build base for debugging. Set HOST_OPT=YES
> in
> CONFIG_SITE. Also, if you save the debugging session in visual c++ and
> email
> it to me I might be able to identify the issue.
> Jeff
> > Sent: Monday, October 18, 2010 7:58 PM
> > To: tech-talk; Jeff Hill
> > Folks,
> > I learned today that it appears that caRepeater has been crashing on
> > this system. I don't know for sure that this problem happens when
> > caRepeater has died, but that seems likely. The next time it happens
> > we will look to see if caRepeater is still running.
> > Meanwhile, we have found that there are caRepeater stackdump files,
> > containing the following:
> > Exception: STATUS_ACCESS_VIOLATION at eip=610B9F69
> > eax=00000000 ebx=00000001 ecx=00000000 edx=0014C6F0 esi=00000000
> > edi=011DCCD8
> > ebp=011DCB14 esp=011DCAEC program=C:\Program Files\EPICS WIN32
> > Extensions\caRepeater.exe, pid 2152, thread unknown (0xC44)
> > cs=001B ds=0023 es=0023 fs=003B gs=0000 ss=0023
> > Stack trace:
> > Frame Function Args
> > 011DCB14 610B9F69 (00000000, 00000000, 00000000, 00000000)
> > 011DCC24 610BA905 (00000000, 00000000, 00000000, 00000000)
> > 011DCCE4 610BB67A (FFFFFFFF, FFFFFFFF, 00000000, 00000000)
> > 011DCD34 61027DE2 (00000002, 011DCE64, 00000002, 011DCE00)
> > 011DCDC8 7C87655C (00000002, 011DCE00, 7C8763C0, 00000002)
> > End of stack trace
> > Has anyone else seen such stackdumps from caRepeater? This is the
> > version of caRepeater.exe that is included in the most recent (Nov. 2,
> > 2007) APS "EPICS Win32 Extensions" package.
> > Thanks,
> > Mark
> > From: Mark Rivers
> > Sent: Wed 10/13/2010 11:14 AM
> > To: tech-talk; 'Jeff Hill'
> > Subject: EPICS CA problems
> > Folks,
> > We are having trouble with a Windows IOC at NSLS. Here are the
> > symptoms:
> > - The IOC is running fine
> > - The PC running the IOC has 2 local CA clients connected to the IOC,
> > medm and IDL. Occassionally (1-2 times per day) one of these clients
> > loses its connection to the IOC. Medm screens go white, IDL says it
> > cannot find a PV, etc. This happens when the client was running fine.
> > It typically only happens to one or the other client, not to both.
> > - Restarting the client fixes the problem.
> > - The same 2 clients are running on another PC connected to the same
> > IOC. Those clients are always fine, they do not lose connection when a
> > client on the PC with the IOC does.
> > - Looking at the resources on the Windows machine (CPU, virtual and
> > physical memory usage) does not indicate any problems.
> > How do we go about figuring out what is wrong?
> > Thanks,
> > Mark
- RE: EPICS CA problems Jeff Hill
- RE: EPICS CA problems Mark Rivers
Re: EPICS on ARM (continued) Dirk Zimoch
Re: ChannelArchiver build problem with 3.14.11 on Suse linux Ernest L. Williams Jr.
<2010>
<2010>
