Hello Kay,
that does not solve the original problem yet.
I have a 64 bit SUSE linux, compiled base 3.14.11 as 32bit because I have to link my IOC with
a vendor (CAEN) supplied library.
Now when I try to build ChannelArchiver I first had the problem that under SUSE the
includes seem to be in different places. Having solved this I still can not link
due to the missing 32bit version of the xerces lib.
I will probably have to make also a 64 bit base and point ChannelArchiver to that.
Burkhard
Am 26.10.2010 um 23:28 schrieb Kasemir, Kay:
> Hello Murali:
>> I am able to build a 32 bit version of the ChannelArchiver from sourceforge
>> under R3-14-11 with some changes to cater to my local environment and one
>> change to ArchiveDataServer.cpp (see patch).
> Based on a brief glance, your patch looks OK, and with the
> #if (EPICS_REVISION = 14 && EPICS_MODIFICATION >= 11)
> it should still work for previous releases, so why don't you commit that to
> the repository.
>> I have installed a later version of XML-RPC and Xerces in /opt/local so I have
>> to make some changes to accommodate that.
> The XML-RPC library used to be a compatibility problem, which is why I
> included specific sources. One thing to watch for is that the sources
> included with the archiver were patched to allow small numbers.
> The XML-RPC standard didn't allow passing numbers in the "1e-10" notation,
> only as "0.0000000001". But the original XML-RPC library used too few digits
> when formatting numbers in to the protocol, so you got "0.000". I patched
> that, but you'd have to check your later version to assert that it still
> passes small numbers.
> Thanks,
> Kay
- Re: ChannelArchiver build problem with 3.14.11 on Suse linux Kasemir, Kay
RE: Some Channel Access Questions Jeff Hill
Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
<2010>
Re: ChannelArchiver build problem with 3.14.11 on Suse linux Shankar, Murali
<2010>
