1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ChannelArchiver build problem with 3.14.11 on Suse linux
Date: Tue, 26 Oct 2010 14:37:52 -0700
>Based on a brief glance, your patch looks OK, and with the
>     #if (EPICS_REVISION = 14 && EPICS_MODIFICATION >= 11)
>it should still work for previous releases, so why don't you commit that to
>the repository
Will do. It is part of a patch branch; I’ll merge this specific change into the HEAD.
>The XML-RPC library used to be a compatibility problem, which is why I
>included specific sources. One thing to watch for is that the sources
>included with the archiver were patched to allow small numbers.
Good to know. I’ll test it with the later version for this use case and switch to using the versions shipped with the source if the problem persists.
Murali
Prev: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Kasemir, Kay
Next: RE: Some Channel Access Questions Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
Next: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
ANJ, 27 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
