1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS on ARM (continued)
To: Dirk Zimoch <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 26 Oct 2010 13:59:22 -0700
Rod, Dirk,
I was able to compile and build the libs for my arm platform.
To my surprise the catools (caget, etc) are not built (only the libs are)
I don't need them for my iocs, but would be nice to have them for troubleshooting.
(my arm linux is the etch debian version, i.e. in theory I could ssh to it and caget from
it). What is the directive to build the <top>/bin/linux-arm_el ?
Obviously the files are built on my linux x86_64 machine.
But how does the arm access those files, i.e what is common practice?
1/ Do you nfs mount the partition on the arm and access the lib from there?
2/ Do you copy the files on the arm? scp, ftp, unison, etc...
3/ Do you nfs mount the arm and build on local machine?
I would prefer my embedded system to be standalone. So 2 and 3 seem to make sense.
But what do you/others do?
Emmanuel
Re: EPICS on ARM (continued) Dirk Zimoch
RE: Thread model for EPICS on ARM CPU michael.abbott
Re: Thread model for EPICS on ARM CPU Rod Nussbaumer
EPICS on ARM (continued) emmanuel_mayssat
Prev: Some Channel Access Questions Ben Franksen
Next: RE: ChannelArchiver build problem with 3.14.11 on Suse linux Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS on ARM (continued) Dirk Zimoch
Next: Re: EPICS on ARM (continued) Dirk Zimoch
ANJ, 27 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
