Hi Emmanuel,
For each cross compile architecture you have several configuration
files. Let's have a look on linux-arm (in configure/os):
> ls -1 *linux-arm*
CONFIG.Common.linux-arm
CONFIG.Common.linux-arm_eb
CONFIG.Common.linux-arm_el
CONFIG.linux-x86.linux-arm
CONFIG.linux-x86.linux-arm_eb
CONFIG.linux-x86.linux-arm_el
CONFIG_SITE.linux-x86.linux-arm
CONFIG_SITE.linux-x86.linux-arm_eb
CONFIG_SITE.linux-x86.linux-arm_el
So we have 3 different cross architectures here (linux-arm,
linux-arm_eb, linux-arm_el). Select one as your starting point.
Either modify the corresponding files (eg. for linux-arm_el:)
or make your own files (*.linux-armv4l), copy or include the existing
files and overwrite what is different yor you.
Then you add the cross architecture to CROSS_COMPILER_TARGET_ARCHS
(either in CONFIG or CONFIG_SITE or CONFIG_SITE.linux-x86.Common) and
run make.
If you have further questions, please ask.
Dirk
[email protected] wrote:
Rod,
I am basically trying to compile EPICS for the TS7370 (arm based arch).
How I achieve this is not important to me.
I looked at the TS cross toolchain.
I understand I am supposed to change my makefiles following
CROSS = /opt/crosstool/gcc-3.3.4-glibc-2.3.2/bin/arm-linux-
CC = $(CROSS)gcc
but how do I do that in EPICS?
I am not even sure how to correctly setup a target architecture...
export T_A=linux-arm; make
or even make T_A=linux-arm
seem to work.
My target EPICS_HOST_ARCH is linux-armv4l
My host is linux 64 bit.
It seems I need to create the files
CONFIG.linux-x86_64.armv4tl
CONFIG_SITE.linux-x86.linux-armv4tl
CONFIG.Common.linux-armv4tl
I copied ../configure/os/CONFIG...linux-arm... files to compile
But I run into several issues...
Is there any resource for cross compiling on EPICS?
Any other info on how you achieve to run epics on a TS7370 is welcome.
On 08:57 Mon 25 Oct , Rod Nussbaumer wrote:
I have also been able to cross compile EPICS and other applications
using the Technologics Systems cross toolchain, but am not using that
for production work.
- Re: EPICS on ARM (continued) emmanuel_mayssat
- RE: Thread model for EPICS on ARM CPU michael.abbott
- Re: Thread model for EPICS on ARM CPU Rod Nussbaumer
- EPICS on ARM (continued) emmanuel_mayssat
RE: EPICS CA problems Jeff Hill
ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
<2010>
<2010>
