1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: cross-gcc-2.9.6 problem
To: 王林 <[email protected]>
Cc: [email protected]
Date: Mon, 25 Oct 2010 10:35:42 +0200
The cross compiler alone solves only half of the problem. If you want to
use the hardware floating point support you need support libraries.
If you have a Windows version of the cross compiler you probably have
the support libraries. Otherwise you will not be able to use hardware
floating point.
王林 wrote:
> Hello,
> Thanks for your advice.Actually,I very want to know that if vxWorks5.5.1
> and the CPU board remain unchanged,is it advisable to improve the
> crossgcc2.9.6 and make it support PPC85xx? Or is there any way to
> extract the cross compiler from Tornado? So far,I have a
> Tornado2.2.1(Windows version)supporting PPC85xx.
> And if possible,what is the workload? How difficult is it?
> Thanks
> Wang Lin
RE:RE: cross-gcc-2.9.6 problem 王林
Prev: R3.14.12-rc1 delayed Andrew Johnson
Next: Re: R3.14.12-rc1 delayed Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE:RE: cross-gcc-2.9.6 problem 王林
Next: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04) Angus Gratton
ANJ, 25 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
