I am not sure if this applies - but the analog input record (and could be put into the AO record) has support for breakpoint tables. A breakpoint table with an entry for each integer is a lookup table. There is some optimization in that code for starting the search for the segment from the location of the last segment. Yes, it applies. The analog output record does support breakpoint tables. So the two-dimensional feed-forward table could be split up into four one-dimensional breakpoint tables (one for each corrector power supply). These could be used in four ao records that fetch their value from the gap position, and use "Raw Soft" support to write the converted values to the PS setpoints. Standard tools and records, neither sequencer nor c code or other magic involved. Breakpoint tables can be reloaded at run time, so should the physicists change the feed-forward tables, you can regenerate and reload the breakpoint tables without rebooting the IOC. (If you use a subroutine record to reload the tables, this can be done by clicking a button.) HTH, Ralph -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Silver Sent: Thursday, October 21, 2010 4:41 AM To: tech-talk Subject: Lookup table problem -- Ralph Lange Bldg.902-B, Rm.18 tel: x8060 NSLS-II Controls Group fax: x8085
ANJ, 21 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
