1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Manipulating time in records
To: "Marty Kraimer" <[email protected]>, <[email protected]>
Date: Thu, 21 Oct 2010 08:53:18 -0400
And there is 32 bits for user specification - so the new time format is
64 bit seconds, 32 bit nsecs, 32 bit user
-----Original Message-----
> To sum up the type aspect:
> - A pair of integer is required&  signed integers are good enough for
now ... provided that UINT32 support is completed within the next 68
years.
> - Relative time (pulse time), with ns precision can fit in a FLOAT64
for 125 hours or something like that, which would be OK for us.
> - A ns precision for a software interrupt is somehow excessive and
microsecond precision would fit into a FLOAT64 mantissa but it's not
very good to have many resolutions.
> We are considering a waveform with 2 ints for time PVs and maybe
FLOAT64 records for relative time (pulse time).
> I also guess that pvData will/shall allow time struct with ns
fractions in the API.
pvData defines a timeStamp that is similar to epics except that seconds
after epoch is
1) An 64 bit signed integer rather than 32 bit signed integer. This
prevents overflow for a really really long time.
2) epoch is posix epoch (Jan 1 1970 at 00:00:00 UTC) rather than epics
epoch (Jan 1 1990 at 00:00:00 UTC)
The nanoseconds within the second is a signed 32 bit integer.
Manipulating time in records Di Maio Franck
Re: Manipulating time in records Luedeke Andreas
RE: Manipulating time in records Di Maio Franck
Re: Manipulating time in records Marty Kraimer
Prev: RE: Lookup table problem Dalesio, Leo
Next: Re: Lookup table problem Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Manipulating time in records Marty Kraimer
Next: Re: Manipulating time in records Luedeke Andreas
ANJ, 22 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
