1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Lookup table problem
To: <[email protected]>, "tech-talk" <[email protected]>
Date: Thu, 21 Oct 2010 08:50:27 -0400
I am not sure if this applies - but the analog input record (and could
be put into the AO record) has support for breakpoint tables. A
breakpoint table with an entry for each integer is a lookup table. There
is some optimization in that code for starting the search for the
segment from the location of the last segment.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Silver
Sent: Thursday, October 21, 2010 4:41 AM
To: tech-talk
Subject: Lookup table problem
hi,
  I need to implement a function for insertion device like this:
  Read a two-dimensions table file from the disk, which is values for
gap positions and Correction coil power supplies (one gap value
corresponding to 4 power supply value). If a gap position is set from
the operator, four power supplies will be set automatically.
I want to use SNC language to do this, for reading the data from disk,
use an asub record for it. Is it ok? Is there any better ways? Did
anyone finish this job before?
  Any suggestions are appreciated.
Best regards
Geyang  2010-10-21
Re: Lookup table problem Ralph Lange
Lookup table problem Silver
Prev: RE: Lookup table problem austen.rose
Next: RE: Manipulating time in records Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Lookup table problem Ralph Lange
ANJ, 21 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
