1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Lookup table problem
To: "tech-talk" <[email protected]>
Date: Thu, 21 Oct 2010 16:40:44 +0800
hi,
  I need to implement a function for insertion device like this:
  Read a two-dimensions table file from the disk, which is values for gap positions and Correction coil power supplies (one gap value corresponding to 4 power supply value). If a gap position is set from the operator, four power supplies will be set automatically.
I want to use SNC language to do this, for reading the data from disk, use an asub record for it. Is it ok? Is there any better ways? Did anyone finish this job before?
  Any suggestions are appreciated.
Best regards
Geyang  2010-10-21
Re: Lookup table problem Maren Purves
RE: Lookup table problem austen.rose
RE: Lookup table problem Dalesio, Leo
Re: Lookup table problem Steven M. Hartman
Re: Lookup table problem Tim Mooney
Prev: Re: Manipulating time in records Luedeke Andreas
Next: RE: Manipulating time in records Di Maio Franck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics C# Library - questions Alain Bertrand
Next: Re: Lookup table problem Maren Purves
ANJ, 21 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
