Hi Pawel,
I didn't give user the possibility to show/hide a trace, but it is possible. To add a "Visibility" property to every trace will make the property sheet longer, so I have to be careful. I think you can set the trace color same as the plot area background color to hide the trace. If there are more people asking the same function, I will add the "Visibility property to every trace.
Xihui
Sent: Friday, October 15, 2010 6:56 AM
To: TechTalk
Subject: CSS XY Graph show/hide traces
Hello,
Is it possible to dynamically show/hide traces according to some flag?
I have a maximum of four traces I want to display on an XY Graph but it
should be possible for the user to switch to 1 or 2 instead of 4.
Is there a way to do it dynamically in CSS or should I just write values
higher (lower) than the maximum (minimum) values of the given trace to
the PV that I don't want to be visible?
Cheers,
Pawel Predki
Technical University of Lodz,
Department of Microelectronics and Computer Science
- RE: CSS XY Graph show/hide traces Zhukov, Alexander P.
- CSS XY Graph show/hide traces PaweÅ PrÄdki
Re: Problem in registerRecordDeviceDriver Xinyu Ao
<2010>
<2010>
