1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem in registerRecordDeviceDriver
To: [email protected]
Cc: Xinyu Ao <[email protected]>
Date: Fri, 15 Oct 2010 08:59:57 -0500
On Thursday 14 October 2010 20:48:15 Xinyu Ao wrote:
>      Iâm using PI C-863 Mercury motor controller to control PI M-126 stage
> under EPICS. I currently use the 6.5.1 version for MotorSrc, PiSrc, and I
> compiled successfully under EPICS version 3.14.11, with supported of
> packages sncseq-2.0.12, asyn4-13-1, ipac-2.10, and
> calc-2-8.  However we encountered an segmentation fault error in executing
> st.cmd when trying to run command of xxx_registerRecordDeviceDriver
> pdbbase.
What hardware and OS is your IOC running on?  Were there any warning or error
messages displayed when you built the IOC binary?  A seg-fault that early
would probably have resulted in one or more warnings, and if so you should
concentrate on resolving them properly (if you need help with that, post the
output from the make process that shows those messages).
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: Problem in registerRecordDeviceDriver Xinyu Ao
Prev: Re: gateway putlog Ralph Lange
Next: Re: gateway putlog Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem in registerRecordDeviceDriver Xinyu Ao
Next: Re: Problem in registerRecordDeviceDriver Xinyu Ao
ANJ, 16 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
