I recently discovered a problem with performing a home search from
the EPICS motor record when using an Aerotech Ensemble motor
controller. The problem is that the EPICS Ensemble driver uses
Aerotech's ASCII communication protocol and that protocol blocks all
communication on ASCII communication ports during a home search.
Consequently, once a home search is started from EPICS, it is unable
to stop it.
Aerotech is aware of the problem and have plans to fix this, but a
release date has not been set yet.
I have made a motor record minor bug fix release (6.5.2) available
here with the home search function commented out of the
Ensemble driver. I advise Ensemble users to upgrade to this
version. Users that need to perform a home search should do it from
Aerotech's IDE software, which can abort a home search.
Ron
RE: MOXA ARM computer and streamDevice Mark Boots
RE: slow caput from R3.14.11 client to R3.14.9 IOC Jeff Hill
<2010>
Re: slow caput from R3.14.11 client to R3.14.9 IOC Andrew Johnson
Re: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error) Sergey Stepanov
<2010>
ANJ, 15 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
