1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: gateway putlog
To: [email protected]
Date: Tue, 12 Oct 2010 19:51:57 +0200
On Dienstag, 12. Oktober 2010, Andrew Johnson wrote:
> On Friday 08 October 2010 21:10:26 [email protected] wrote:
> > I was wondering where the writes to the put log are done in the
> > gateway source code? I would like to try to modify the source to
> > allow multiple gateways to write this information to a central
> > database, but I'm having a bit of a hard time finding the calls in
> > the code.
> I believe this is done through an Access Security hook, so the
> gateway calls an asLib routine to check rights and that calls back
> into the hook routine. If you look at the documentation for asLib in
> the Application Developers' Guide you should find something about
> that, but if not ask again and I'll go hunting.
Right, at least that is how it is done on the IOC. You can even
configure put logging in the access security configuration file; IIRC
the gateway has such a file, too.
Note that --again, this is how it works on the IOC-- neither access
security, nor any other part of the IOC knows anything about caPutLog.
Instead, the initialization routine of the caPutLog facility registers
a callback with access security (calling asTrapWriteRegisterListener),
which in turn does the actual logging via calls to logClientSend (see
src/libCom/logClient in base).
Cheers
Ben
Re: gateway putlog Ralph Lange
gateway putlog pthomas
Re: gateway putlog Andrew Johnson
Prev: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Andrew Johnson
Next: Re: gateway putlog Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: gateway putlog Andrew Johnson
ANJ, 12 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
