Hi Patrick,
On Friday 08 October 2010 21:10:26 [email protected] wrote:
> I was wondering where the writes to the put log are done in the gateway
> source code? I would like to try to modify the source to allow multiple
> gateways to write this information to a central database, but I'm having a
> bit of a hard time finding the calls in the code.
I believe this is done through an Access Security hook, so the gateway calls
an asLib routine to check rights and that calls back into the hook routine.
If you look at the documentation for asLib in the Application Developers'
Guide you should find something about that, but if not ask again and I'll go
hunting.
HTH,
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: gateway putlog Ben Franksen
- gateway putlog pthomas
No motion and No homeStatus motor:6.51/VxWorks:6.8/base 3.14.11: No change with a new motor.h Jerome HOSSELET
Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Andrew Johnson
<2010>
<2010>
