Interesting. I am able to print the drawings (at least on the Toshiba e-STUDIO205 printer next door). The explicit conversion to PostScript (via either the 'Export to PostScript' menu item or the 'Print as PostScript' menu item) that fails.
On Oct 8, 2010, at 11:36 AM, Nicholas P. DiMonte wrote:
Never tried it before, but on my Window machine I
get an error saying "PostScript not supported on selected printer"
even on a post-script printer.
I have never been successful printing from VDCT.
Nick D.
On 10/8/2010 1:12 PM, Eric Norum wrote:
A while back I posted a message about my inability to convert VDCT drawings to PostScript:
VDCT -- 2.6.1274 on OS X and on LInux
When I try to export as PostScript I get the following error:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:979)
at java.lang.StringBuffer.insert(StringBuffer.java:446)
at com.cosylab.vdct.VisualDCT.printGrid(Unknown Source)
at com.cosylab.vdct.VisualDCT$1MyOwnPostScriptExportingThread.run(Unknown Source)
Is there some setting that I've missed? Some workaround that will let this proceed?
I received no responses thus leading me to believe that:
A) VDCT is dead.
or
B) No one else has a problem with this conversion.
or
C) No one else needs to get PostScript images for inclusion in other documentation or archival in a document control system.
So -- which of the above statements is true?
Hopefully,
- VDCT PostScript problem Eric Norum
- Re: VDCT PostScript problem Eric Norum
- Re: VDCT PostScript problem Nicholas P. DiMonte
Re: VDCT PostScript problem Matthieu Bec
Base R3.14.12-pre1 ready for testing Andrew Johnson
<2010>
Re: VDCT PostScript problem Pete R. Jemian
<2010>
ANJ, 08 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
