Hi Eric,
I don't normally use this feature. Quick check here gives me the same
problem. One work around: select 'print preview', click the print button
there, use something like cups-pdf (linux) that worked for me.
Might not be very helpful if you bulk process a bunch of schematics from
command line (if that option exists).
Matthieu
On 10/08/10 14:12, Eric Norum wrote:
A while back I posted a message about my inability to convert VDCT drawings to PostScript:
VDCT -- 2.6.1274 on OS X and on LInux
When I try to export as PostScript I get the following error:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:979)
at java.lang.StringBuffer.insert(StringBuffer.java:446)
at com.cosylab.vdct.VisualDCT.printGrid(Unknown Source)
at com.cosylab.vdct.VisualDCT$1MyOwnPostScriptExportingThread.run(Unknown Source)
Is there some setting that I've missed? Some workaround that will let this proceed?
I received no responses thus leading me to believe that:
A) VDCT is dead.
or
B) No one else has a problem with this conversion.
or
C) No one else needs to get PostScript images for inclusion in other documentation or archival in a document control system.
So -- which of the above statements is true?
Hopefully,
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- VDCT PostScript problem Eric Norum
- Re: VDCT PostScript problem Eric Norum
Re: VDCT PostScript problem Pete R. Jemian
<2010>
seq pvPut to a waveform Dayle Kotturi
<2010>
