1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VDCT PostScript problem
To: "[email protected] tech-talk" <[email protected]>
Date: Fri, 8 Oct 2010 11:12:53 -0700
A while back I posted a message about my inability to convert VDCT drawings to PostScript:
> VDCT -- 2.6.1274 on OS X and on LInux
> When I try to export as PostScript I get the following error:
> java.lang.StringIndexOutOfBoundsException: String index out of range: -1
> 	at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:979)
> 	at java.lang.StringBuffer.insert(StringBuffer.java:446)
> 	at com.cosylab.vdct.VisualDCT.printGrid(Unknown Source)
> 	at com.cosylab.vdct.VisualDCT$1MyOwnPostScriptExportingThread.run(Unknown Source)
> Is there some setting that I've missed?   Some workaround that will let this proceed?
I received no responses thus leading me to believe that:
A) VDCT is dead.
or
B) No one else has a problem with this conversion.
or
C) No one else needs to get PostScript images for inclusion in other documentation or archival in a document control system.
So -- which of the above statements is true?
Hopefully,
Eric Norum
[email protected]
Re: VDCT PostScript problem Nicholas P. DiMonte
Re: VDCT PostScript problem Matthieu Bec
VDCT PostScript problem Eric Norum
Prev: RE: Equipment with EPICS support Krempasky Juraj
Next: Re: VDCT PostScript problem Nicholas P. DiMonte
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: VDCT PostScript problem Eric Norum
ANJ, 08 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
