1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS at Sandia
To: [email protected]
Cc: "Akridge, Charles S. \(MSFC-ES52\)" <[email protected]>
Date: Mon, 4 Oct 2010 15:15:42 -0500
Hi Scott,
On Monday 04 October 2010 14:47:52 Akridge, Charles S. (MSFC-ES52) wrote:
> A NASA group is traveling to White Sands Test Facility in late October
> (around the 27th) and weâre considering using EPICS for a low-speed (1000
> samples/sec) data acquisition system for the propulsion test stands and
> would like to see EPICS in use at Sandia National Labs. Is anyone willing
> or can you give me a contact to possibly set-up a tour?
If you know anyone at White Sands that uses EPICS you may be better off
contacting them directly.  There are at the moment no subscribers to tech-talk
with a sandia.gov email address, and only two messages in the archive, both
dated 2003.
> NOTE: I sent this message out originally Friday afternoon and thought it
> may have gotten overlooked thatâs why the second try.
In this case I think the silence means there's nobody here that can answer
your request.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: EPICS at Sandia Akridge, Charles S. (MSFC-ES52)
Prev: EPICS at Sandia Akridge, Charles S. (MSFC-ES52)
Next: Re: EPICS at Sandia Akridge, Charles S. (MSFC-ES52)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 04 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
