Hello Dirk,
Actually here we use two embedded computers with x86 processor from
Moxa, DA-682 and DA-710. DA-682 is 2U high with 2 PCI expansion slots
which supports up to 16 serial ports. DA-710 is 4U high with 4 PCI
expansion slots which supports up to 32 serial ports. In addition,
DA-710 also comes with 2 serial ports. The main difference besides is
that DA-710 has dual power input. Both these two models come with VGA,
USB, CompactFlash.
Huijuan
-----Original Message-----
[mailto:[email protected]] On Behalf Of Hu, Yong
Sent: Monday, October 04, 2010 12:19 PM
To: Dirk Zimoch
Cc: EPICS tech-talk
Subject: RE: MOXA ARM computer and streamDevice
Hello Dirk,
For me using Moxa DA66x, there's no major problem in the cross
compiling, just need some configurations to build
cross-compiler(xscale_be) and EPICS base(i.e. specify
'CROSS_COMPILER_TARGET_ARCHS', 'GNU_DIR', etc.).
Yes, the NFS server is running on the Moxa box.
Another alternative for computer with multiple serial ports would be
Moxa DA-710 (http://www.moxa.com/product/DA-710.htm ). It's x86
processor and more powerful than little ARM. It comes with 4 Ethernet
ports and 2 RS-232. If need more serial ports, buy the 8-port
RS-232/422/485 expansion module cards (they have 'serial optical
isolation' version) and insert the modules into DA-710 PCI slots(~4).
DA-710 can be shipped with Debian/Linux on a hard-disk so that we can
take advantage of EPICS Debian packages(i.e. base, softioc, procserv,
iocstats, etc.) available from NSLS-2(http://epics.nsls2.bnl.gov/debian/
Cheers,
Yong
NSLS-II Controls Group
>From: Dirk Zimoch [mailto:[email protected]]
>Sent: Monday, October 04, 2010 8:57 AM
>To: Hu, Yong
>Cc: Martin Konrad; EPICS tech-talk
>Subject: Re: MOXA ARM computer and streamDevice
>Hello Yong,
>I am also interested in this issue.
>What is the problem in the cross compiling process?
>Can I use NFS on the DA66*?
>Are there other alternatives (i.e. 19" computers with many RS232/485
>ports)? So far I used a solution with an additional PC providing remote
>tty devices. But I like the idea of running EPICS directly on the
>machine with the ttys.
>Dirk
>Hu, Yong schrieb:
>> Hi Martin,
>> I played with Moxa DA662(2 more Ethernet ports than DA661) for a
while
>and made it work with base(3.14.10) + asyn(4.10) + StreamDevice(2.4).
>The cross compiler(linux-xscale_be) source code is from Moxa, but we
>rebuilt it. The whole cross compiling process takes some efforts. I can
>send you the static cross-complied executable(base, asyn and stream all
>included) if you want.
>> My application is to monitor 1-wire temperature sensors (~20K) for
>NSLS-2. We need 90 Moxa DA662, that's a big number. For better system
>maintenance and software development, I'm going to abandon Moxa DA-662
>and changing to use 5 powerful and stable servers(multiple cpu cores)
to
>handle all 1-wire stuff. Another reason I don't like Moxa DA66x is that
>the Linux/Debian inside Moxa has limited tools/commands so that it's
>painful to use.
>> Hope you make a good decision.
>> Yong
- MOXA ARM computer and streamDevice Martin Konrad
- RE: MOXA ARM computer and streamDevice Hu, Yong
- Re: MOXA ARM computer and streamDevice Dirk Zimoch
EPICS at Sandia Akridge, Charles S. (MSFC-ES52)
<2010>
RE: MOXA ARM computer and streamDevice Mark Boots
<2010>
