Hello Yong,
I am also interested in this issue.
What is the problem in the cross compiling process?
Can I use NFS on the DA66*?
Are there other alternatives (i.e. 19" computers with many RS232/485
ports)? So far I used a solution with an additional PC providing remote
tty devices. But I like the idea of running EPICS directly on the
machine with the ttys.
Dirk
Hu, Yong schrieb:
Hi Martin,
I played with Moxa DA662(2 more Ethernet ports than DA661) for a while and made it work with base(3.14.10) + asyn(4.10) + StreamDevice(2.4). The cross compiler(linux-xscale_be) source code is from Moxa, but we rebuilt it. The whole cross compiling process takes some efforts. I can send you the static cross-complied executable(base, asyn and stream all included) if you want.
My application is to monitor 1-wire temperature sensors (~20K) for NSLS-2. We need 90 Moxa DA662, that's a big number. For better system maintenance and software development, I'm going to abandon Moxa DA-662 and changing to use 5 powerful and stable servers(multiple cpu cores) to handle all 1-wire stuff. Another reason I don't like Moxa DA66x is that the Linux/Debian inside Moxa has limited tools/commands so that it's painful to use.
Hope you make a good decision.
Yong
-----Original Message-----
[email protected]] On Behalf Of Martin Konrad
Sent: Friday, October 01, 2010 2:20 PM
To: EPICS tech-talk
Subject: MOXA ARM computer and streamDevice
Hi all,
we are thinking about running IOCs for RS232 devices on ARM based data
aquisition computers from MOXA (DA-661):
http://store.moxa.com/j2bc_ext/doc/prodbase/M20090309140/DA-660-
I_Series.pdf
Can someone who already works with similar devices tell us if this
should work
with base + asyn + streamDevice? What tool-chain did you use for cross
compiling? Did it work smoothly? What are your experiences regarding
time
effort for cross compiling? - Of course setting up a standard Linux PC
together
with a simple device server does the same job. But fewer devices/PCs
means
less trouble...
best regards
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel: +49-6151-16-5121
Fax: +49-6151-16-4321
- RE: MOXA ARM computer and streamDevice Hu, Yong
- MOXA ARM computer and streamDevice Martin Konrad
Re: seq pvPut to a waveform Ben Franksen
<2010>
<2010>
ANJ, 04 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
