Hi Mark,
the executables in base and asyn are all sucessfully built.
I've used makeBaseApp.pl to create the Makefiles and other stuff for
building my IOC application. This two seems to work.
The application builts for linux-x86 target. Only for linux-cris_v10
I get the error.
Florian
On Fri, 1 Oct 2010, Mark Rivers wrote:
Florian,
Can you confirm that you successfully built some executables, like the ones in base (caput, caget) and the ones in asyn (testAsynPortDriver). Look in the bin/linux-x86 directories there. If so, then we need to figure out why it is failing to build your IOC appplication, which it built other programs OK. Is it just the size of the resulting program or something else?
What happens if you use makeBaseApp.pl to build the example IOC applicaton? Does that build OK?
Sent: Fri 10/1/2010 7:01 AM
To: Burkhard Kolb
Cc: Mark Rivers; tech-talk Mailing List; Florian Feldbauer
Subject: Re: Cross compiling EPICS for cris v10
PLT seens to mean "procedure linkage table". The compiler source code is
here:
https://www.calcforge.org/trac/emu-tigcc/browser/tiemu/trunk/src/core/gdb/bfd/elf32-cris.c?rev=1818
Of course, that does not mean that I have any clue what caused the error.
Dirk
Burkhard Kolb wrote:
Well Mark,
Peter Zumbruch posted the same error some time ago on 28th of June (subject: No PLT for relocation)
At that time nobody responded ...
We also still have no solution, it seems to be a linker problem with the cris-gnu stuff.
Burkhard
Am 30.09.2010 um 18:04 schrieb Mark Rivers:
I have never seen an error like that.
What type of system are you building for, an embedded IOC or a
workstation?
You are using asyn R4-10 which is quite old, and was tested with EPICS
3.14.8, but I don't think that is the problem. Could you be running out
of memory on the target system?
It did build the executables in the asyn test directories OK, right? So
the linker can build executables, just not your IOC executable?
-----Original Message-----
Sent: Thursday, September 30, 2010 10:29 AM
To: Mark Rivers
Cc: Florian Feldbauer; [email protected]
Subject: RE: Cross compiling EPICS for cris v10
Ok, now I was able to build synApps (Stream, Asyn, Calc, and sscan). But
still I can't build my IOC application
/usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
xis-linux-gnu/bin/ld:
/usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/lib/linux-cris_v10/li
basyn.a(devAsynInt32.o):
No PLT for relocation R_CRIS_32_GOTPLT against symbol
`epicsRingBytesCreate' from .text section
final link failed: Bad value
collect2: ld returned 1 exit status
make[3]: *** [slowCtrl] Error 1
make[3]: Leaving directory
`/usr/Epics/slowCtrl/slowCtrlApp/src/O.linux-cris_v10'
make[2]: *** [install.linux-cris_v10] Error 2
make[2]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp'
make: *** [slowCtrlApp.install] Error 2
Florian
Dr. Burkhard Kolb
Pleikartsförster Str. 38
69124 Heidelberg
Germany
E-Mail: [email protected]
Tel: +49 6221 718640 / Fax: +49 6221 718641
| Florian Feldbauer |
| Ph.D. student |
| Institut für Experimentalphysik I |
| Ruhr-Universität Bochum |
| Universitätsstr. 150 |
| D-44780 Bochum |
| Office: NB 2/173 |
| Phone: (+49)234 / 32-23538 |
| Fax: (+49)234 / 32-14170 |
| Web: http://www.ep1.rub.de |
- RE: Cross compiling EPICS for cris v10 Mark Rivers
- Cross compiling EPICS for cris v10 Florian Feldbauer
- RE: Cross compiling EPICS for cris v10 Florian Feldbauer
- Re: Cross compiling EPICS for cris v10 Burkhard Kolb
- Re: Cross compiling EPICS for cris v10 Dirk Zimoch
Re: Channel Archiver overlapping blocks Kasemir, Kay
<2010>
<2010>
ANJ, 01 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
