Good idea - we got a hint from the hardware vendor that there might be a vxWorks 6.7 "SMP Perfomance Patch" which should solve 'similar' problems. - We'll check with WRS. Hello Matthias-- The "Page Fault Addr : 0x00000000" looks very suspicious. Null pointer somewhere? Strange that is is occurring in what looks to be deep within tNetTask. I would second the suggestion to apply recommended patches for 6.7. We started putting VxWorks 6.7 into production during our summer maintenance period (~8 IOCs so far), so the longest running production IOC with this version is less then 2 months uptime. But we have not seen any such problems in testing or production. We do have all WRS recommended patches as of July 9 (from trying to debug a geiEnd driver problem for the mv5500, fixed in 6.8 by the way). Unfortunately all of the network diagnostics do not work after a crash of the net task. We saw this before with 5.5 and it does make it very difficult to debug. In our case, memory corruption was occurring from another task writing beyond a malloc'd buffer, clobbering the meta data and making a mess of the free list. That task would end up suspended during either a malloc or free, so it ended up holding the semaphore protecting malloc/free. Apparently, tnetTask (at least in 5.5) does lots of malloc/free so we would find the suspended task promoted to priority 50 with tnetTask waiting on it to get the semaphore (and thus no network). The console shell would work, but a number of the show routines also use malloc. If you use any of those, the shell ends up blocking on the same semaphore and your only option is a reboot. Does 'i' show anything promoted to a higher priority for you?
ANJ, 30 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
