I do not do much EPICS anymore, but this thread triggers
memories on annoying issues. The main issue seems to be memory usage, but
this affects many other aspoects of the IOC.
Can I make a suggestion that the length of the CALC field be fixed by
the designer, but configurable through a new field, perhaps called CLEN.
The default value of CLEN would of course be 40 if not otherwise
specified.
Yes, I know that this is a BIG change in a fundamental record
type and must be handled with real care for backwards compatability.
It is surely too late to make such a major change in
the 3.14 code, but aiming the change at 3.15 would give time to think the issues
through in more detail.
Some points:
1) Most CALC expressions are quite small and fixed, so in
memory-challenged applications it would be useful to set CLEN to some small
number like 5.
2) If increasing the size of CALC makes
RPCL too big, can I point out that cascading CALC records because the CALC field
is too small also chews up memory.
3) Expressions can be considerably clarified
with the addition of whitespace and parentheses, but the current tight
limitation seriously discourages developers from including these useful
characters. Anthing that improves the clarity of the calculation will cut developer time and make
subsequent maintenace easier.
4)
Cascading CALC records because the CALC field is too small makes the expressions
more difficult to read, and the overhead of processing multiple records can
impact the performance of the whole IOC.
5) Way
back, around 2004 I think it was, Tim Mooney helped me with a with a
customization of the postfix and calcPerform routines that allowed expressions
like MAX(A,B,C), which are much more compact than MAX(A,MAX(B,C)). These
never made it into base because they broke expressions like A?B,
which I never used because they leave unpredictable numbers of
items on the stack, but which turn out to be common in some applications.
If the CALC record is reworked, can I suggest that this issue be
re-examined at the same time?
I will
shut up now,
Russell O. Redman
On Sep 29, 2010, at 9:02 AM, Andrew Johnson wrote:
We *could*
make RPCL into a char* pointer and allocate it dynamically according to
the particular _expression_, but that means making code changes to the
record and also opens up the possibility of free memory fragmentation on
vxWorks IOCs (none of the other standard record types allocate memory
after initialization to avoid that). I think it's too late to make
those kind of changes at this point.
How long has it
been since someone actually tested vxWorks to see if it still exhibit
this fragmentation issue?
Sometimes urban legends are just that.
Alternatively we could add integer literal support to the code in
libCom/calc, which would reduce the incremental expansion factor from
21/4 to 10/3 or better, but again that would be making code changes
uncomfortably late in the development cycle for
3.14.12.
Are the changes that extensive?
I would not worry /too/ much about wasted space.
After all, every record
has a 41-character DESC field, most of them are
permanently empty, and I
don't recall hearing complaints about
that.
Making CALC 80 translates to RPCL being 419 bytes
instead of its current 209 bytes. Lewis' suggestion of 64 bytes
translates to RPCL being 335 bytes. Do any small-IOC guys want to
weigh in on these suggestions? I'm about ready to admit
defeat.
Plus, making the integer literal change could make the RPCL increase much
less significant (or even non-existent)
