On Sep 29, 2010, at 9:02 AM, Andrew Johnson wrote: ...
We *could* make RPCL into a char* pointer and allocate it dynamically according to the particular _expression_, but that means making code changes to the record and also opens up the possibility of free memory fragmentation on vxWorks IOCs (none of the other standard record types allocate memory after initialization to avoid that). I think it's too late to make those kind of changes at this point.
How long has it been since someone actually tested vxWorks to see if it still exhibit this fragmentation issue? Sometimes urban legends are just that. Alternatively we could add integer literal support to the code in libCom/calc, which would reduce the incremental expansion factor from 21/4 to 10/3 or better, but again that would be making code changes uncomfortably late in the development cycle for 3.14.12.
Are the changes that extensive? I would not worry /too/ much about wasted space. After all, every record
has a 41-character DESC field, most of them are permanently empty, and I
don't recall hearing complaints about that.
Making CALC 80 translates to RPCL being 419 bytes instead of its current 209 bytes. Lewis' suggestion of 64 bytes translates to RPCL being 335 bytes. Do any small-IOC guys want to weigh in on these suggestions?
I'm about ready to admit defeat. Plus, making the integer literal change could make the RPCL increase much less significant (or even non-existent)
- Re: CALC expression Andrew Johnson
- RE: CALC expression Redman, Russell
- CALC expression Andrew Wagner
- Re: CALC expression Tim Mooney
Re: CALC expression Pam Gurd
<2010>
<2010>
ANJ, 29 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
