1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CALC expression
To: Andrew Wagner <[email protected]>
Cc: [email protected]
Date: Tue, 28 Sep 2010 15:58:38 -0700
No one suggested this but ... you can also put your constant as input!
0.00835 then becomes D, etc...  with just that change you saved 12 chars!
E
On 13:03 Tue 28 Sep     , Andrew Wagner wrote:
> Hey everyone,
> I need to evaluate a somewhat complicated conditional statement in a calc record. Presently I need to evaluate:
>  field(CALC, "(235>B && 5>D && 5>E) ? (B*0.00835 - 0.7 > A + (C-B)*0.25 ? B*0.00835 - 0.7: A + (C-B)*0.25): 0")
> where the letters are input variables. When I load the record I get the error
> Can't set "VOLT:PID.CALC" to "(235>B && 5>D && 5>E) ? (B*0.00835 - 0.7 > A + (C-B)*0.25 ? B*0.00835 - 0.7: A + (C-B)*0.25): 0"
> Error at or before ")" in file "MagnetCtrlApp/Db/MagnetCtrl.db" line 113
> Does CALC not support nested evaluations? Perhaps I need a subroutine record? Any advice would be greatly appreciated.
> Cheers,
> Andrew
Emmanuel
Re: CALC expression Matthieu Bec
CALC expression Andrew Wagner
Prev: Re: CALC expression J. Lewis Muir
Next: Re: CALC expression Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CALC expression Eric Norum
Next: Re: CALC expression Matthieu Bec
ANJ, 29 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
