Tim & Andrew,
but you can to the same thing with 4 calc records that do the
4 fields Tim wrote out below without needing any special
records that somebody/a site may or may not have, no?
Maren
Tim Mooney wrote:
Andrew,
You don't need a subroutine record for this. You might be able to get
it into a single calcout
record using techniques folks have already mentioned, but as they've
noted, the result might
be hard to understand.
I would do this with a transform record, if the record is available.
You'd have 16 calc-type expressions, each with a comment to describe it,
all in one record,
so you could break this into separate expressions and then combine the
results.
For example:
field(CLCF, "235>B && 5>D && 5>E")
field(CLCG, "B*0.00835-0.7")
field(CLCH, "A+(C-B)*0.25")
field(CLCI, "F?(G>H?G:H):0)
Actually, I'd rewrite that last expression as
field(CLCI, "F?MAX(H,G):0")
This seems to me easier to understand and modify than the equivalent
implementation
with calcout records.
Tim
On 9/28/2010 3:03 PM, Andrew Wagner wrote:
(235>B&& 5>D&& 5>E) ? (B*0.00835 - 0.7> A + (C-B)*0.25 ? B*0.00835
- 0.7: A + (C-B)*0.25): 0
- CALC expression Andrew Wagner
- Re: CALC expression Tim Mooney
Re: CALC expression Matthieu Bec
<2010>
<2010>
