1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: error compiling base R3-14-11
To: [email protected]
Date: Tue, 28 Sep 2010 16:02:07 +0200
Hi Gabriele,
> An error occurs when I try to install base R3-14-11 on Ubuntu (GNU make
> vers is: 3.81-7):
I'm using Ubuntu 10.04, too.
> ?../src/libCom/osi/os/default/epicsReadline.c:76:31: error:
> readline/readline.h: Nessun file o directory?
> readline- devel package is already installed.
That sound's strange. Please double check you have installed libreadline6-dev.
If that package already is installed try reinstalling it:
aptitude reinstall libreadline6-dev
readline.h should be located in /usr/include/readline/ after that.
If the problem remains: Did you mess with your include path?
Best regards
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel: +49-6151-16-5121
Fax: +49-6151-16-4321
error compiling base R3-14-11 gabriele marano
Prev: Re: error compiling base R3-14-11 Jack
Next: archiving system Dirk Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: error compiling base R3-14-11 J. Lewis Muir
ANJ, 28 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
