1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: always more inputs in gensub/asub
To: [email protected]
Cc: [email protected]
Date: Mon, 27 Sep 2010 11:54:25 -0700
On 09:43 Mon 27 Sep     , [email protected] wrote:
> However, you need asynMotor support for your motor controller. By the
> sound of it you are trying to control the motor directly, so this isn't
> much help.
Yes, I am not using asynMotor. Maybe I should have but I didn't.
And now that I have a full blown motor driver, hard to change as I may lose
expertise and worse many functionalities.
For example, I have 2 types of synchronous move.
1/ Program the hardware and finally ask the hardware to move. That works great.
2/ Compute everything in the software and send a long atomic command.
For each physical motor I have:
* Backlash
* Prelash (to limit deadband when a motor change direction)
* Last direction of move (to see if prelash should be applied)
* Encoder position
* Reference position (internal to motor controller)
* Move in step
* Mode: relative move, absolute move, no move
> If your previous post is related (which I assume it is), note that:
>  * you need a recent version of EPICS (R3.14.11) to support "long
> strings as char waveforms"
So far so good.
>  * You need to be putting the data into a record field that is large
> enough to take the data. Hence, the stringOut record is still limited by
> the 40 character hard size of the field definition. If you are using
> stream device you can use a waveform record with a FTVL of CHAR or
> UCHAR. You can also use the asynRecord.
Are you saying my strings should be waveform records?
Do you have a sample db file?
BTW, I went back to the epics manuals... I cannot find any mention of this.
I conclude it is expert knowledge..
E
always more inputs in gensub/asub emmanuel_mayssat
RE: always more inputs in gensub/asub nick.rees
Prev: Re: always more inputs in gensub/asub Dirk Zimoch
Next: Re: Long string ... emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: always more inputs in gensub/asub nick.rees
Next: Re: always more inputs in gensub/asub Dirk Zimoch
ANJ, 27 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
