So do you have a workaround? Use streamDevice for everything except the waveform, and the asyn record for that?
Sent: Sun 9/26/2010 5:41 PM
To: Mark Rivers; Dirk Zimoch; [email protected] tech-talk
Subject: Re: StreamDevice slowdown
Hmm...
I have an asyn record in my application already.
So, I set up a bug buffer when I instantiate it:
dbLoadRecords "db/asynRecord.db" "P=tfb:,R=asyn,PORT=L0,ADDR=-1,OMAX=0,IMAX=33554432"
Then at the end of the st.cmd file:
dbpf tfb:arm Arm
DBR_STRING: "Arm"
epicsThreadSleep 1
dbpf tfb:softTrigger 1
DBR_STRING: "Trigger"
epicsThreadSleep 1
dbpf tfb:asyn.OFMT ASCII
DBR_STRING: "ASCII"
dbpf tfb:asyn.IFMT Binary
DBR_STRING: "Binary"
dbpf tfb:asyn.AOUT "Waveform?"
DBR_STRING: "Waveform?"
And the 'seconds per megasample' are:10.24
10.24
10.25
10.25
10.24
10.25
10.24
10.25
10.24
10.24
10.25
10.25
10.24
10.24
10.25
10.24
So, the smoking gun appears to be in StreamDevice's hand.....
On Sep 26, 2010, at 3:29 PM, Mark Rivers wrote:
> To be sure that the problem is streamDevice rather than something else in EPICS, you could use the asynRecord to do the tests. Put the OFMT=ASCII, IFMT=Binary, and make the IMAX be large enough to hold your waveform when you boot the IOC.
> Mark
> ________________________________
> From: Eric Norum [mailto:[email protected]]
> Sent: Sun 9/26/2010 5:25 PM
> To: Mark Rivers
> Cc: [email protected]; Dirk Zimoch
> To check the raw transfer speed I did:
> telnet -c 192.168.1.159 73 >/dev/null
> and typed in the 'Waveform?\n" command.
> The times per megasample for 16 megasamples in this case:
> 10.25
> 10.24
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.24
> So I'm pretty sure that the slowdown is in the StreamDevice processing somewhere.
> By way of comparison, here are the 16 'seconds per megasample' values when using ASYN/StreamDevice rather than telnet:
> 16.78
> 48.18
> 80.91
> 113.86
> 147.28
> 180.20
> 211.65
> 244.36
> 278.61
> 308.90
> 342.91
> 374.54
> 408.60
> 439.26
> 473.29
> 505.54
> On Sep 26, 2010, at 2:40 PM, Mark Rivers wrote:
>> Have you turned on asynTrace in the low-level (TCP?) driver and sent the output to a file so it does not slow things down too much? Can you see then what's on the wire?
>> Mark
> Eric Norum
> [email protected]
Eric Norum
[email protected]
- Re: StreamDevice slowdown Eric Norum
- StreamDevice slowdown Eric Norum
- RE: StreamDevice slowdown Mark Rivers
<2010>
<2010>
