1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: pyepics bug (need fix asap!) + Matthew Newville?
To: [email protected]
Date: Wed, 22 Sep 2010 10:37:08 -0500
Hi Matt,
On Wednesday 22 September 2010 09:56:55 Matt Newville wrote:
> OK, I was able to reproduce the problem on a linux x86_64 machine.
> For Python, I see that
> >>> import ctypes
> >>> ctypes.c_long == ctypes.c_int
> is True on 32 bit systems but is False on 64-bit linux.  As I said, I
> was mapping Epcics DBR_LONG to a ctypes.c_long.   My suspicion is that
> an Epics DBR_LONG is actually not a "long" on 64-bit machines, but a
> 32-bit integer, which is to say an int.  Perhaps someone can confirm,
> correct, or clarify this.
That is correct, there was too much EPICS software that assumed a DBR_LONG was
always 32 bits, so we map DBR_LONG (and DBF_LONG inside the IOC) to an
epicsInt32 which is our architecture-independent typedef.  If someone needs
anything longer I'd suggest using a DBR_DOUBLE, which can accurately represent
all integers up to 52 bits long (above that you can find that x+1 == x).
> I use ctypes.c_long and ctypes.c_ulong all over dbr.py for the mapping
> of various CA structures, including event and connection handling and
> in the more complex data (DBR_CTRL_XXX, etc).  But callbacks and at
> least some complex data types appear to be working, so some portions
> of these structures must really be longs.  I'll have to do more
> testing on 64-bit machines to better sample over all the mappings of
> the C structures.
Things might appear to work on little-endian machines but not on big-endian or
vice versa; test this on both (Sparc or PowerPC) and x86 families if you can.
The DBR_XXX_LONG structures do use 32-bit values for the limit values.
On a related subject, be aware that in a DBR_CTRL_DOUBLE the alarm limits will
be NaN values if the relevent xxSV field is NO_ALARM; you might want to make
sure that Python handles them properly.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: pyepics bug (need fix asap!) + Matthew Newville? Matt Newville
pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
Re: pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
Prev: Re: pymsi - a python alternative to msi Andrew Johnson
Next: Re: pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: pyepics bug (need fix asap!) + Matthew Newville? Matt Newville
Next: Re: pyepics bug (need fix asap!) + Matthew Newville? Matt Newville
ANJ, 22 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
