Subject: |
Re: pyepics bug (need fix asap!) + Matthew Newville? |
Matt Newville <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Wed, 22 Sep 2010 06:38:11 -0500 |
Hi Emmanuel,
Sorry for the trouble (and I do read tech-talk, sometimes early in the
morning). I don't see that behavior, at least on the first machine I
tested it on (linux-x86). Using both python2.6 and python3.1, I get
the expected values for longs:
millenia:~>caget 13XRM:m1.RRBV
13XRM:m1.RRBV -20000
millenia:~>python
Python 2.6 (r26:66714, Nov 3 2009, 17:33:38)
[GCC 4.4.1 20090725 (Red Hat 4.4.1-2)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
Imported history from: '/home/newville/.pyhist'
>>> import epics
>>> epics.__version__
'3.0.8'
>>> p = epics.PV('13XRM:m1.RRBV')
>>> print p.info
== 13XRM:m1.RRBV (native_long) ==
value = -20000
char_value = '-20000'
count = 1
type = long
units = mm
host = sonata.cars.aps.anl.gov:5064
access = read-only
status = 0
severity = 0
timestamp = 1285154637.998 (2010-09-22 06:23:57.998245)
upper_ctrl_limit = 1240000
lower_ctrl_limit = -1240000
upper_disp_limit = 1240000
lower_disp_limit = -1240000
upper_alarm_limit = 0
lower_alarm_limit = 0
upper_warning_limit = 0
lower_warning_limit = 0
PV is internally monitored, with 0 user-defined callbacks:
I don't think it's an issue with the version of pyepics, as nothing
has changed in the mapping of the Epics database types to the python
ctypes types: An Epics DBR_LONG becomes a ctypes.c_long.
What system are you working on, and how were Epics base and python
built? Could this be an issue with 64bit machines?
Sorry for the trouble,
--Matt Newville <newville at cars.uchicago.edu> 630-252-0431
On Wed, Sep 22, 2010 at 12:27 AM, <[email protected]> wrote:
> Hello,
> I have been using epics and python for quite some time now.
> Just recently I moved to the excellent pyepics.
> The only issue... long type PVs!
> I am about to upgrade to the latest version (pyepics 3,0,8) since I am using an older one (3.0.1)
> But here is what I see:
> epics2@cr1com1 $ caget DMC2183:1:AEncdrPstnLI
> DMC2183:1:AEncdrPstnLI -1833
> in python:
> -------> print(pv.info)
> == DMC2183:1:AEncdrPstnLI (long) ==
> value = 4294965463
> char_value = 4294965463
> count = 1
> type = long
> units = Steps
> host = cls1ir-eth0:5064
> access = read/write
> status = 0
> severity = 0
> timestamp = 1285131880.264 (2010-09-21 22:04:40.263942)
> upper_ctrl_limit = 0
> lower_ctrl_limit = 0
> upper_disp_limit = 0
> lower_disp_limit = 0
> upper_warning_limit = -7872675053568
> Notice the reported value as ...
> value = 4294965463
> It seems there is an issue with bit ordering.
> It works well for double records though.s ;-)
> Based on the pdf doc, the maintainer is Matthew Newville at U Chicago.
> Is he on the mailing list? Anyone knows how to contact him?
> I should have contacted him a long time ago....
> Best,
> Emmanuel
> Emmanuel
- Re: pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
- pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
Re: vlinac and point release J. Lewis Muir
<2010>
<2010>
