1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: vlinac and point release
From: "Akridge, Charles S. (MSFC-ES52)" <[email protected]>
To: Andrew Johnson <[email protected]>, "Akridge, Charles S. (MSFC-ES52)" <[email protected]>
Date: Mon, 20 Sep 2010 21:44:48 -0500
Andrew,
Thank you for taking the time to do this. I definitely appreciate it.
Scott
> From: Andrew Johnson <[email protected]>
> Date: Mon, 20 Sep 2010 18:03:18 -0500
> To: "[email protected]" <[email protected]>
> Cc: "[email protected]" <[email protected]>
> Hi Scott,
> On Monday 20 September 2010 17:38:28 Akridge, Charles S. (MSFC-ES52) wrote:
>> Downloaded and attempted to run ³startProbe.command² but found out that the
>> build is for PowerPC not Intel. I have a MacBook Pro running MacOSX 10.6.4
>> and would prefer to get a point release for this Mac but if not I need I
>> need to understand how to compile vlinac for this machine.
> Building the MEDM, StripTool and Probe extensions is quite a lot of work if
> all you want to do is try out EPICS.  I'll see what I can do tomorrow about
> rebuilding the vlinac against a more recent version of EPICS Base and will
> include the darwin-x86 host architecture.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harald Welte
Re: vlinac and point release Andrew Johnson
Prev: RE: o.c.swt.widgets: ... Szalata, Zenon M.
Next: Re: Stream Device With Parameters Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: vlinac and point release Andrew Johnson
Next: Re: vlinac and point release Andrew Johnson
ANJ, 21 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
