On Thursday 16 September 2010 08:57:37 Ralph Lange wrote:
> I would think that camonitor for the complex structures would yield a
> hard to read, if not unusable output.
We could provide an option to output the complex structures using JSON,
although it might be better to provide this functionality in a separate
program. Suggested output:
tux% cajson -d DBR_CTRL_DOUBLE -mvap anj:aiExample
"anj:aiExample": {
"field_type": "DBF_DOUBLE",
"value": 0,
"status": "UDF",
"severity": "INVALID",
"units": "Volts",
"precision": 1,
"lower_disp_limit": 0,
"upper_disp_limit": 10,
"lower_alarm_limit": null,
"lower_warning_limit": null,
"upper_warning_limit": null,
"upper_alarm_limit": null,
"upper_ctrl_limit": 0,
"lower_ctrl_limit": 10,
I'm using "null" for NaN values since JSON doesn't permit them in numerics,
although I guess they could be expressed as "nan" instead. I think each CA
monitor event should output a complete JSON object, although I'm not sure
whether parsers will like this. The cajson program could use -m to mean
monitor and do a ca_get_callback if you don't specify it.
Having created the above example I realize one problem with the DBR_CTRL_xxx
types is that they don't include a time-stamp, so they're not very good for
monitoring values that change over time.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Testing the new DBE property in EPICS R3-14-11 Xu, Chengcheng
- Re: Testing the new DBE property in EPICS R3-14-11 Ben Franksen
- Re: Testing the new DBE property in EPICS R3-14-11 Ralph Lange
Re: controlling cross compiled build products Andrew Johnson
<2010>
<2010>
