1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Can devices supported in areaDetector include Jai and Imperx?(links to the data sheets )
To: <[email protected]>, <[email protected]>, <[email protected]>
Cc: [email protected], [email protected]
Date: Wed, 15 Sep 2010 10:00:52 +0100
I've been looking at an areaDetector driver for GigE Vision compliant cameras. Several manufacturers produce SDKs (normally tied to hardware ordered from themselves) that will talk to any GigE vision camera, unfortunately there are many licensing issues with producing an open source SDK that implements the standard: http://en.wikipedia.org/wiki/GigE_vision
Having said this, there appears to be a reverse engineered solution using the gnome libraries:
I'm not a lawyer, so I don't know about the legalities of reverse engineering a closed standard to create open source software.
I tried out an early version of this on a Fedora machine, and was able to make it talk to a prosilica (AVT) camera, but ran out of time to do anything apart from run the test program. Both your cameras seem to be GigE Vision compliant, so this may be a route that's worth pursuing...
Tom Cobb,
Diamond Light Source Ltd.
Diamond House
Harwell Science and Innovation Campus
Didcot
Oxfordshire
OX11 0DE
Tel +44 (0) 1235 778582
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 14 September 2010 20:55
To: [email protected]; [email protected]
Cc: kaiyongwu; [email protected]
Hi Tracy,
Those cameras are not currently supported as far as I know.  Unfortunately it is not yet possible to write a generic driver for GigE cameras, so a different driver must be written for each vendor’s cameras using their SDK library.
It is not very difficult to write a driver, so if you want to use those cameras you could do that.
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Sunday, September 12, 2010 8:46 PM
Cc: 'kaiyongwu'; [email protected]
Subject: Can devices supported in areaDetector include Jai and Imperx
Hello,
I would like to confirm whether 1327GE (JAI)and B1410 (IMPERX)cameras supported in areaDetector?
Links to the data sheets:
TM-1327GE(JAI):  1392*1040, 30fps, GigE
http://vision.lusterinc.com/UploadFile/assistant/Camera/JAI/DS-RM-RMC-1327GE.pdf
 IGV-B1410C(IMPERX):  1392*1040, 30fps, GigE
http://vision.lusterinc.com/UploadFile/assistant/Camera/Imperx/DS_bobcat_IGVB1410_low.pdf
Thank you for your time!
Best regards,
Meng Xindong
Tracy Meng
cid:__0@Foxmail.net
Vision & Imaging Components Business Unit
LUSTER LightTech Group
T: +8621 - 66306660
F: +8621- 66306663
E-mail: xindongmeng@lusterinc.com
www.lusterinc.com
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdo! m
Can devices supported in areaDetector include Jai and Imperx?(links to the data sheets ) 孟欣东
RE: Can devices supported in areaDetector include Jai and Imperx?(links to the data sheets ) Mark Rivers
Prev: RE: Can devices supported in areaDetector include Jai and Imperx?(links to the data sheets ) Mark Rivers
Next: RE: Stream Device With Parameters Gorka Ronda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: streamDevice hex format input Gorka Ronda
ANJ, 15 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
