1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject:
Date: Tue, 14 Sep 2010 14:52:33 +0200
Hello everyone,
Using streamDevice, How can I run the command dbtr like a function with parameters? Something like:
Function (parameter 1, parameter 2)
How do I have to write the protocol and record? There are currently as follows:
HI = \x04;
LO = \x57;
cmd4 = \xC0\x04\xFB${HI}${LO}\x00\x00\x00\x00%<xor>;
c4 {
    out "\$cmd4";
    in "%*4r";
record(bi, "$(P):$(R):C4")
    field(DESC, "Command 4")
    field(DTYP, "stream")
    field(INP,  "@devwbc6600.proto c4 $(PORT) $(A)")
What I want is not to specify the values of the variables HI and LO in the archive .proto. I want to give them values when I call the command dbtr (another command to process the records?), to give these variables the hexadecimal value I want, each time I run the command.
Thanks in advance,
Gorka
Re: Stream Device With Parameters Dirk Zimoch
Prev: Strange gateway error message Dirk Zimoch
Next: Re: Stream Device With Parameters Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Strange gateway error message Jeff Hill
ANJ, 16 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
