1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asynchronous record behavior
To: [email protected]
Cc: [email protected]
Date: Mon, 13 Sep 2010 16:23:12 -0700
When you have records performing asynchronous input it is often better to "push" data through a sequence of records rather than to "pull" it as you are now doing.
Could you restructure your database to have the $(MUX)VOLT:Chan203 FLNK to the calc and calcout records?   FLNK processing would not be done until the $(MUX)VOLT:Chan203 record had actually received the result of the MEAS:VOLT:DC? query so the calc and calcout records would have up-to-date values.
On Sep 13, 2010, at 2:56 PM, [email protected] wrote:
> Hey everyone,
> I'm having a problem with a calcout record that seems to process before it has passed control to its input record(s). I have a database with two records,
> record(calc, "Current:Coil") {
>  field(DESC, "Coil Current")
>  field(SCAN, "Passive")
>  field(MDEL, ".1")
>  field(ADEL, ".1")
>  field(INPA, "Current:Coil.VAL  NPP")
>  field(INPB, "$(MUX)VOLT:Chan203.VAL  PP MS")
>  field(CALC, "A + B")
>  field(PINI, "NO")
>  field(EGU, "A")
>  field(SDIS, "0")
> record(calcout, "Voltage:Output") {
>  field(DESC, "Output Voltage")
>  field(INPA, "Current:Coil.VAL  PP MS")
>  field(OOPT, "Every Time")
>  field(DOPT, "Use CALC")
>  field(CALC, "A")
>  field(OUT, "$(VLTPROG)P25V.VAL PP MS")
>  field(PINI, "YES")
>  field(EGU, "V")
>  field(SDIS, "0")
> and when I start my ioc, I get:
> Starting iocInit
> ## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
> ## EPICS Base built Sep  2 2010
> 2010/09/13 14:37:11.593 172.25.100.69:1234 write 32
> MEAS:VOLT:DC? (@203)\n++read eoi\n
> 2010/09/13 14:37:11.593 172.25.100.97:1234 write 25
> APPL P25V, 0.000000, 0.1\n
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq sncxxx,"user=andrewwagnerHost"
> epics> 2010/09/13 14:37:11.870 172.25.100.69:1234 read 16
> +8.92303000E-04\n
> It seems the calcout record processes at init (as desired) passes control to input A which issues the MEAS:VOLT:DC? command but doesn't wait for input A to actually return a value. Input A returns control to the calcout record too quickly so if I print the record I get:
> epics> dbpr Voltage:Output
> A: 0                ASG:                B: 0                C: 0
> CALC: A             D: 0                DESC: Output Voltage
> DISA: 0             DISP: 0             DISV: 1             DLYA: 0
> E: 0                F: 0                G: 0                H: 0
> I: 0                J: 0                K: 0                L: 0
> NAME: Voltage:Output                    OCAL: 0             OEVT: 0
> OVAL: 0             POVL: 0             PVAL: 0             SEVR: INVALID
> STAT: LINK          TPRO: 0             VAL: 0
> with an INVALID LINK. How can I guarantee that control from the input is not passed back to the calcout record until it has finished measuring the voltage? Should I set SDIS "Current:Coil.PACT" ? Thanks very much for your help.
> Andrew
Eric Norum
[email protected]
Re: asynchronous record behavior Andrew Wagner
asynchronous record behavior apwagner
Prev: asynchronous record behavior apwagner
Next: Re: asynchronous record behavior Andrew Wagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 13 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
