Hi Gorka,
I found if you want to read raw byte, you need to use
in “%4.4r”
as the input format. Please give a try. The Streamdeive
document doesn’t clearly mention this.
-Yuke
Hi all,
I’m using streamDevice, attempting to
communicate with a device sending and receiving in hex format. I achieve to
make right the sending, but I have problems with the receiving. I write the
following in the protocol file:
cmd1 =
\xC0\x01\xFE\x00\x00\x00\x00\x00\x00%<xor>;
c1 {
out "\$cmd1";
# in
"\xA0\x55\xAA\x5F";
# in 0xA0 0x55 0xAA 0x5F
# in "%s";
in "%*4r";
Like you could see I try different options
for input, but any of those and others I try work for me. I like to have an
input in hex like, 0xA0 0x55 0xAA 0x5F or A0 55 AA 5F in my soft IOC. Instead,
I have the following, which could be ASCII:
epics> 2010/09/13 15:20:08.440
/dev/ttyS0 read 1
\240
2010/09/13 15:20:08.442 /dev/ttyS0 read 3
U\252_
What I have to write exactly for the input?
This is the record I use for that command.
What type of record should I use?
record(bi, "$(P)$(R)C1")
field(DESC,
"Comando 1")
field(DTYP,
"stream")
field(INP, "@devwbc6600.proto
c1 $(PORT) $(A)")
This is the st.cmd file:
cd ${TOP}
dbLoadDatabase
"dbd/wbc6600test.dbd"
wbc6600test_registerRecordDeviceDriver
pdbbase
# Set up ASYN ports
# drvAsynSerialPortConfigure port ipInfo
priority noAutoconnect noProcessEos
drvAsynSerialPortConfigure("L0","$(TTY)",0,0,0)
asynSetOption("L0", -1,
"baud", "115200")
"bits", "8")
"parity", "none")
"stop", "1")
"clocal", "Y")
"crtscts", "N")
asynOctetSetInputEos("L0", -1,
"\n")
asynOctetSetOutputEos("L0", -1,
"\n")
asynSetTraceIOMask("L0",-1,0x2) #0x7
para todos los mensajes
asynSetTraceMask("L0",-1,0x9) #0x1f
## Load record instances
dbLoadRecords("db/devwbc6600.db","P=$(P),R=$(R),PORT=L0,A=0")
dbLoadRecords("db/asynRecord.db","P=$(P)$(R),R=asyn,PORT=L0,ADDR=-1,OMAX=0,IMAX=0")
## Start EPICS
cd ${TOP}/iocBoot/${IOC}
iocInit
Thanks in advance,
Gorka
