ä 2010å09æ10æ 10:28, Mark Rivers åé:
Are you sure you set EPICS_CA_MAX_ARRAY_BYTES on both the server and the client machines?
Sent: Thu 9/9/2010 9:17 PM
To: [email protected]
Subject: ca client get waveform pv error
Hi all,
I am use a edm client get a waveform pv(640*480 ),the IOC has enough
memory,but only one client can get the pv data,when another client try
to connect to this pv,the client get the error message:
CA value callback('pic1'): No data, CA status The requested data
transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
But ,I set the EPICS_CA_MAX_ARRAY_BYTES to a big number(1600000000),is
there some other options need to be configured?
Thanks for your help.
wantianmin
Hi,Mr Mark and Mr Eric,
this is my shell command to run the ioc and the edm client,
ioc command:
#!/bin/bash
#saveredirfile.pl /home/wantm/ioc.txt
export EPICS_CA_MAX_ARRAY_BYTES=1600000000
export EPICS_CA_SERVER_PORT=5064
cd /usr/local/epics/apps/iocBoot/iocexample
./st.cmd
edm client:
#!/bin/bash
export EPICS_CA_ADDR_LIST="10.30.1.40"
export EPICS_CA_AUTO_ADDR_LIST=NO
edm -x /home/wantm/ccd_new/dmc.edl
Best regards
- ca client get waveform pv error wantianmin
- RE: ca client get waveform pv error Mark Rivers
RE: Re: ca client get waveform pv error Mark Rivers
Re: ca client get waveform pv error wantianmin
<2010>
Re: ca client get waveform pv error Eric Norum
<2010>
